Author Topic: Star Wars - MAME settings help required please [SOLVED]  (Read 3490 times)
shrunkenmaster
  • Last login:July 24, 2022, 10:17:33 am
« on: September 23, 2010, 01:55:28 pm »
I'm getting sound stuttering upon the Death Star explosion that I don't get on another machine with similar spec. Anyone have any suggestions with what I can try? I've exhausted everything I can think of, except more RAM. System details:
P4 2.4Ghz / 512Mb RAM / GeForce FX5200 / Direct X 9.0 / XP Pro
MAME INI:
<UNADORNED0>
# CORE CONFIGURATION OPTIONS
readconfig              1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                 roms
samplepath              samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                 ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
state_directory         sta
snapshot_directory      snap
diff_directory          diff
comment_directory         comments
hiscore_directory       hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip           0
frameskip               0
seconds_to_run            0
throttle                1
sleep                   0
speed                     1.0
refreshspeed              1
# CORE ROTATION OPTIONS
rotate                    1
ror                     0
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
# CORE ARTWORK OPTIONS
artwork_crop            0
use_backdrops           1
use_overlays            1
use_bezels              1
# CORE SCREEN OPTIONS
brightness              1.00
contrast                  1.0
gamma                   1.00
pause_brightness        0.65
# CORE VECTOR OPTIONS
antialias               1
beam                    1.00
flicker                 0.00
# CORE SOUND OPTIONS
sound                   1
samplerate              22000
samples                 1
volume                  0
# CORE INPUT OPTIONS
coin_lockout              1
# ctrlr                 <NULL> (not set)
mouse                   0
joystick                1
lightgun                0
multikeyboard             0
multimouse                0
steadykey               0
offscreen_reload        0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
uimodekey                 auto
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                     0
verbose                 0
update_in_pause           0
debug                   0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                   0
skip_gameinfo           0
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
# WINDOWS DEBUGGING OPTIONS
oslog                   0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                  0
maximize                1
keepaspect              1
prescale                  1
effect                  none
waitvsync               0
syncrefresh             0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch               1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution              auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer            0
switchres               0
full_screen_brightness  1.00
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency           2
# INPUT DEVICE OPTIONS
dual_lightgun           0
« Last Edit: September 23, 2010, 02:28:16 pm by shrunkenmaster »
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
Re: Star Wars - MAME settings help required please
« Reply #1 on: September 23, 2010, 01:59:49 pm »
I wouldnt even run XP for web surfing with 512MB of RAM!
When the PC runs out of physical memory it uses your hard disk instead and thats much slower and will cause disk thrashing and sound chopping.
My MAME system isnt much more than yours except I have 2GIG memory and it never does that.
Mines a P4 2.4Ghz with a crap $10 PCI-E graphics card but 2gig physical mem
« Last Edit: September 23, 2010, 02:07:09 pm by Smeghead »
My MAME Build:
Havok
  • Trade Count: (+17)
« Reply #2 on: September 23, 2010, 02:01:53 pm »
That's a pretty low end system. Have you tried using an older version of Mame? Newer versions are more power hungry. Since they are similar specs, it might just be the other system is slightly better where it counts for Mame. Besides going with an older Mame version, make sure you have the latest video and sound drivers on your system as well.
If that doesn't work, try enabling the autoframeskip...
« Last Edit: September 23, 2010, 02:06:02 pm by Havok »
shrunkenmaster
« Reply #3 on: September 23, 2010, 02:08:31 pm »
Stop laughing at my system ;D - got it for next to nothing and thought I'd give it a try...
Any idea what version of Mame to try? Am I correct in thinking the graphic engine got overhauled after 0129?
If an older version doesn't change anything, do you think adding RAM would?
shrunkenmaster
« Reply #4 on: September 23, 2010, 02:27:27 pm »
Thanks everyone. Just tried Mame 0129 and the sound is fine. The game seems to run OK, will find some more RAM just for fun.
JustMichael
  • Mmmmm!! Cheesecake!!
Re: Star Wars - MAME settings help required please [SOLVED]
« Reply #5 on: September 23, 2010, 03:58:12 pm »
This wouldn't help and might hinder your sound but for starwars, I use -beam 1.75 -flicker .25 and -resolution 1680x1050 (my lcd monitor's resolution).  Star Wars looks like when I was a kid.
JODY
  • Last login:January 19, 2024, 05:06:29 pm
  • After a long delay...the arcade is underway!
« Reply #6 on: September 23, 2010, 08:15:37 pm »
I'm running it fine on a 1.6 Ghz PC with 512 MB of RAM at 1024x768.  Don't recall the exact version of Mame and don't have it handy at the moment.  The latest does stutter the sound but the older version is fine.
« Last Edit: September 23, 2010, 08:17:14 pm by JODY »
Havok
« Reply #7 on: September 24, 2010, 01:07:23 pm »
Don't bother - anything above 512MB won't give you any noticeable performance gain.
DaveMMR
    • TeeVee Games
« Reply #8 on: September 25, 2010, 12:16:02 pm »
Agreed from what I've seen on my own (similar) setup.  However, depending on how you have XP setup (do you have a FE as the shell, are you using TinyXP, turn off nonessential services, etc.), it'll still be beneficial for the OS running MAME.  Also, I found games (particularly Neo Geo) load faster with more memory.
shrunkenmaster
« Reply #9 on: September 26, 2010, 12:23:04 pm »
Thanks again guys, appreciate the advice. I've used TinyXP on other computers so I'll do the same here.
Then I'll be able to install my 4-terabyte Hyperspin setup and launch Gauntlet Legends  ;D
jimmy2x2x
« Reply #10 on: September 26, 2010, 12:35:36 pm »
hahahahah
