Main > Project Announcements
Bartop - Capcom ITX (Complete)
Pages: << < (8/9) > >>
JBBOPT:
could you upload the lower rez video? Thanks
Pitman:
--- Quote from: JBBOPT on May 16, 2011, 11:41:40 am ---could you upload the lower rez video? Thanks
http://dl.dropbox.com/u/2681459/arcade/Intro.zip
Pitman:
Art printed and nothing left to buy or sort out.
Bit of plexi cutting and plexi spraying tomorrow then she's pretty much done.
Created the jig for the joystick earlier and it fits snug which is lucky as I only had one spare bolt to hold it in with.
Pitman:
She's done... well almost, just gotta add the back door, clean up some of the scratches add cut a bit of plexi to the bottom (where the black button is) and add the network socket at the rear.
I'm pretty happy with it but could have improved it in a few areas, this being my first cab i'm overall pleased with how it turned out.
Pitman:
Couple useful things I found that may help people:
quick sheller - works great.
a network port at the back - really useful, saves taking a usb pen over and you can shell one account and use another account just for remote desktop if you have to go in and change something.
As nice as White is, it gets dirty easily and scratches are to make when slotting control panels in etc.
ITX (at least this one) is quite a nice solution, they're small, generate little heat and leave  you a lot of space. As I said earlier, 3d games are pretty much out.
A mains splitter cable, saved more space in the case.
Cold cathode, I got one from ebuyer for a few quid, they generate no heat and give out a good amount of light
usb powered speakers, again saves space.
if adding a front facing sticker, make sure you apply it slowly making sure to get rid of the air bubbles
even clear superglue is visible.
cutting plexi - careful not to heat it too much when using power tools. I went for a stanley knife in the end.
plexi scratches sooo easily, be careful.
Right, time for a bit of Pang now :)
Go to full version
