Main > Project Announcements
Bartop - Capcom ITX (Complete)
Pages: << < (4/9) > >>
njay:
Good skills  !  :applaud:
Pitman:
did a little rom testing to see the limitations of the board:
hyperspin - is fine, as long as you turn a lot of the options down (as mentioned earlier) and use a lower res intro video
* classic roms - eg pang, bubble bobble etc - fine
* street fighter 2 series - fine
* street fighter 3 - fine, was hoping 3rd strike would play good and it does, if I hit the accelerate key it's max speed is +250%.
* killer instinct 2 - it plays though it's not really playable, if I hit the accelerate key it's max speed is +70%.
i've not tried the other 3d games but it's probably safe to say that it's pretty much 2d only on this board.
Anyone know a way of increasing the initial startup time of roms that use NVRAM? perhaps some ram storage?
njay:
Strange I ran Ki2 on my old PIV 3.0 GHZ with 2GB ram fine
Mame loves Ram also how much you did you add? also try to use if you have 64 bit installation mame64
Pitman:
a 3ghz p3 would beat it, higher clock and in mame the multithreading doesn't really do too much.
I've not seen the ram usage go over 330mb on xp x64 yet using mame64
njay:
isn't there some special mame versions for dual core cpu's?
you can try this
Enable -multithread (aka -mt).
Go to full version
