Main > Project Announcements
Gamesomnia - inspired by Knievel's Woody Cab
Pages: << < (7/12) > >>
Rick:
--- Quote from: ragnar on September 15, 2010, 07:54:27 pm ---Any bets on how long wiring will take?  My bet is 2 hours.  Which means it really will take 4 hours, right?   ;D
Always pull a Scotty.  Estimate how long, and then double or triple your estimate. Then, when you beat the clock, everybody's impressed.
(I'm so jealous by the way. You get to work on yours, and it's SO CLOSE!)
javeryh:
Hmmm.... I like what you did with the overlay.  Also, I noticed you did not mitre the bottom of your CP box?  Is it visible  at all?  I'm going to be recutting mine for the THIRD time because I can't seem to get the joints to line up but now I'm wondering if it is worth it.
mrtuesday42:
is that the previously mentioned vinyl on your cp??? super shiny if it is...or did you cover in acrylic? been looking at vinyl or something inexpensive to cover my sides with...
ragnar:
--- Quote from: Rick on September 15, 2010, 08:04:13 pm ---
Hahahaa, about 4 hours in and 70-80% done.
ragnar:
--- Quote from: mrtuesday42 on September 16, 2010, 01:48:54 am ---is that the previously mentioned vinyl on your cp??? super shiny if it is...or did you cover in acrylic? been looking at vinyl or something inexpensive to cover my sides with...
It is vinyl covered with aryllic, so that is why it is shiny.  I spent $7 on some vinyl so it was a big cost cutter.  I needed vinyl to cover the joystick mounting plates of the u360s.
In the end, you can not tell it is vinyl unless you look very closly.  Kind of a bummer because I was hoping that the wrinkly (leather like) texture of the vinyl would show a bit more.
Thinking about it, vinyl could be used to good effect on sides, just remember that it easily scratches.  If you are moving the cabinet and bang it against a wall, the vinyl will show that fact.
Go to full version
