Author Topic: Help with the ultimate button layout!  (Read 2575 times)
  • Last login:May 06, 2024, 04:31:28 pm
« on: August 26, 2010, 03:58:47 pm »
Can one of you photoshop geniuses please do me a favor?  Can you take the button layout below and put a border around it?  I'd like to see what both of my awesome mock-ups look like.  I want something to surround the button and joysticks on my CP so I'm planning to cut out some vinyl but I need something to trace/layout on the vinyl before attempting to cut it out.  The goal is to do what is done HERE but my button layout is a bit different.  And yes, the second design looks like a wang.
Huge thanks to anyone who can hook me up!   :cheers:
EDIT: Oh yeah, I want to be able to print the layout in actual size!  Also, some guide lines would help (like the button centers, etc.)...
« Last Edit: August 26, 2010, 04:01:22 pm by javeryh »
EvilNuff
Re: Help with the ultimate button layout!
« Reply #1 on: August 26, 2010, 05:11:04 pm »
Not 100% sure what you want but something like this?
The half circles aren't very rounded here but if you elaborate a bit I can do what you want pretty easily if I'm on the right track.
« Reply #2 on: August 26, 2010, 05:30:20 pm »
Yes!  That is exactly what I'm talking about (with more rounded ends - the center point of the joystick should be the center point for the 1/2 circle on the left and then just try and make it look proportionate on the other end I guess).  I want to print it out, tape it to the vinyl and then cut it out with a razor (for the straight parts) and scissors for the curves.
THANKS!!
EvilNuff
« Reply #3 on: August 26, 2010, 05:53:52 pm »
How are these...
As for printing that will depend on your graphics app...I just modified the original file you provided.
« Reply #4 on: August 27, 2010, 09:30:36 am »
Those look great!  So how do I print them out?  The file I posted prints to scale - can you attach your modified files to a post here?
How hard do you think it will be to cut these shapes out of vinyl?  I think I can already tell I'm going to go with the bottom one...   :cheers:
  • Last login:May 09, 2023, 01:16:55 pm
« Reply #5 on: August 27, 2010, 09:32:43 am »
I hope you do.  The one above looks a little bit cockeyed.
sstralkowski
  • Last login:July 09, 2012, 03:14:38 pm
  • Rock Out with Macaque Out!
« Reply #6 on: August 27, 2010, 11:13:27 am »
:laugh2: :laugh2: :laugh2:
EvilNuff
« Reply #7 on: August 27, 2010, 11:44:47 am »
I used http://www.getpaint.net/ to modify the images.
Here is the pdn file: http://dl.dropbox.com/u/208302/ubl-rounded.pdn
And here is the png file version: http://dl.dropbox.com/u/208302/ubl-rounded.png
I figure both verisons lets you do more if there's something in the png version you did not like.  ;D
Edit: In theory the changed versions should print the same as your original...if they don't let me know and I'll figure out why.
« Reply #8 on: August 27, 2010, 11:47:52 am »
Thanks a ton - I'll let you know how it goes.  Cutting out the rounded sections is going to be tough...
« Reply #9 on: August 27, 2010, 11:48:11 am »
I know!
« Reply #10 on: August 27, 2010, 11:59:59 am »
My Post: 1 -- Word Filter: 0.
EvilNuff
« Reply #11 on: August 27, 2010, 12:33:30 pm »
You're just cutting out in Vinyl right?  Find a can or plate thats the correct size and use that to cut around...don't free hand it. :)
Ginsu Victim
  • Comanche, OK -- USA
« Reply #12 on: August 27, 2010, 12:48:20 pm »
I was thinking the same thing. Place something round (of the appropriate size) on it and take an exacto knife around it.
« Reply #13 on: August 27, 2010, 12:53:59 pm »
Good idea guys.  I wish I had one of those vinyl cutters!
