Author Topic: How do you build a nice looking front door panel?  (Read 3438 times)
ragnar
  • Last login:August 16, 2022, 10:40:56 am
« on: August 25, 2010, 05:24:37 pm »
I've one some searching on the forums and have not found any discussions on this matter.  I want my front panel to be removable or to be hinged.
Removable I can do but I would prefer hinged.  But how do I do a nice clean look and make it hinged?
I know the ideas behind it, but I have not seen pictures of this kind of work.  So I am basically hoping that some of you fine folk would be so kind as to post some pictures of your front doors!  Anything that opens up (hinged or removable) to provide access to the inner guts is appreciated!
UPDATE
:  This is my current curiosity and potential solution to all my issues:
Is this what I need:
http://www.woodcraft.com/Product/2080761/29849/E-Z-Mount-Hinges-Soft-Close-Full-Inset-Hinge.aspx?refcode=10INAFFG
Same as this (which my local Ace Hardware might carry)?:
http://www.acehardware.com/product/index.jsp?productId=3622277&kw=cabinet+hinge&origkw=cabinet+hinge
UPDATE:
Ya, these:
http://www.homedepot.com/h_d1/N-5yc1vZ1xga/R-100149058/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
ORDERED:
Atleast Home Depot doesn't beat around the bush.  These are full inset hinges!
« Last Edit: August 29, 2010, 01:00:14 am by ragnar »
MY FIRST BUILD:
  • Last login:May 06, 2024, 04:31:28 pm
Re: How do you build a nice looking front door panel?
« Reply #1 on: August 25, 2010, 05:51:56 pm »
THIS is how I did it.
methodical
  • Last login:July 05, 2012, 07:31:51 pm
« Reply #2 on: August 25, 2010, 06:52:55 pm »
yep, that's how I did it... cabinet door hinges.
Avrus
  • Last login:September 07, 2011, 09:17:25 pm
  • Canada
    • The Avrus Arcade Project 'Conquest'
« Reply #3 on: August 25, 2010, 08:43:22 pm »
Super easy just used European hinges, route out the hinge into the side of the cabinet and voila.
HERE
______________________________
'Conquest' upright 4 player arcade project log:
http://avrus.blogspot.com/
ragnar
« Reply #4 on: August 26, 2010, 10:39:03 am »
But how does one make it so the seams for the door look good?
(PS: I don't see the images right now as most of them are blocked at work)
Also, if using just a sheet of plywood, won't it warp if just hanging hinged on one side?  I mean 5 years from now?  Or do peole brace the back side of it?
I'm starting to think that I might do some exposed hinges on the front side and actually have it be a 2 piece door but I think it might look stupid when completed.  I guess the whole idea is to hide the fact that there is a door there.
Do people generally just make the face piece and use hte entire face for the door?
MY FIRST BUILD:
EvilNuff
« Reply #5 on: August 26, 2010, 11:50:50 am »
Think of a kitchen cabinet...they don't sag or warp over years of far more use than any arcade cabinet.  And to be honest many kitchen cabs are a frame with an insert which is less material than a solid plywood or mdf door.  Kitchen cabinet hinges work fine to prevent sagging.
As for seams, google european hinges and see how they work.  That should answer most of your questions.
ragnar
« Reply #6 on: August 26, 2010, 12:36:00 pm »
I'm familiar with the hinges, it's just that the panel has to fit between the two side panels.  Does one just leave a gap of 1/8" or so on each side?  I guess that is the only way.
MY FIRST BUILD:
« Reply #7 on: August 26, 2010, 01:38:04 pm »
1/8" is plenty - I think I tried for 1/16".  Once you have everything in front of you it is easier than you think.
ragnar
« Reply #8 on: August 26, 2010, 01:42:37 pm »
Ya, this is probably true.  I am probably buying the wood today.  Might even get started tonight even though I want to get the sticks ordered ASAP.
MY FIRST BUILD:
EvilNuff
« Reply #9 on: August 26, 2010, 05:12:18 pm »
...I'm familiar with the hinges, it's just that the panel has to fit between the two side panels.  ...
Ahh I misunderstood your question, my bad...Javeryh answered you I believe. :)
ragnar
« Reply #10 on: August 26, 2010, 07:20:52 pm »
Actually, I wouldn't call my question "well formed".  A failure on my part to some extent.  I worry about doing the job and regretting how it turns out.  I think I am going to use every inch of that piece of oak plywood I have and don't want to spend an extra $50 on another because of a mistake :-)
MY FIRST BUILD:
ragnar
« Reply #11 on: August 27, 2010, 11:02:19 pm »
Today I went to Home Depot to get some full inset cabinet hinges.  They don't sell them.
Lowe's also did not have them online.  Some specialty wood working sights sell them though.
So, where is everyone buying these?
« Last Edit: August 27, 2010, 11:24:56 pm by ragnar »
MY FIRST BUILD:
jbarnatt
  • Last login:March 19, 2014, 05:38:03 pm
  • I built it, now I have to push it.
    • Let me build your arcade cabinet
« Reply #12 on: August 27, 2010, 11:17:33 pm »
Here is a tip. You can get those hinges at IKEA. Just go to the AS-IS section. There will be a bin full of random hardware. You can usually get a bag for a few dollars. Not just hinges.
ragnar
« Reply #13 on: August 27, 2010, 11:25:53 pm »
For thet cost of gas to get to one, I'd spend less buying online.  Not a bad idea though!
MY FIRST BUILD:
EvilNuff
« Reply #14 on: August 27, 2010, 11:31:00 pm »
I go to the local rockler store...but the ikea suggestion is amazing.  I will be going there tomorrow to check that out. :)
ragnar
« Reply #15 on: August 28, 2010, 11:25:23 pm »
« Last Edit: August 29, 2010, 01:01:29 am by ragnar »
MY FIRST BUILD:
EvilNuff
« Reply #16 on: August 30, 2010, 12:04:42 am »
As jbarnatt said Ikea was a win for me for hinges.  They had bags of 3 pairs of hinges for $0.99.
That's a boat load cheaper than any hinges i've seen elsewhere.
ragnar
« Reply #17 on: September 09, 2010, 10:47:07 am »
I went with gaps that will be just under 1/8".  Like 1/32" less.  So, the gap on each side is about 3/32".  Maybe a bit more.
Anyways, one I had the hinges in hand and played with them a bit, I could easily see how these work.  So, the door has the holes in it and it is now ready for stain/poly.
Thanks all!
MY FIRST BUILD:
