Author Topic: mame keeps changing my button setup?  (Read 1858 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
« on: August 25, 2010, 05:19:22 pm »
i have mame running fine but with one problem every time mame starts it for some reason changes my joystick button 16 to 15 and that is set to my start button
WhereEaglesDare
    • My HomePage
Re: mame keeps changing my button setup?
« Reply #1 on: August 25, 2010, 06:49:17 pm »
button 16? I dont understand
wooowman93
« Reply #2 on: August 25, 2010, 07:02:50 pm »
i am using a gp-wiz which is a gamepad and maps the button as joystick button 1, 2, 3, etc....
bkenobi
« Reply #3 on: August 25, 2010, 08:21:06 pm »
Make your default.cfg file read only and see if it still changes.
wooowman93
« Reply #4 on: August 25, 2010, 08:27:25 pm »
i was playing with the default.cfg file and found the for some reason if its joycode 16 or under it subtracts one. so if it is 15 in the cfg it will be 14 in mame and for some reason it doesn't do the same with 17?
severdhed
  • RIP Dinosaur Hippo
« Reply #5 on: August 25, 2010, 08:31:49 pm »
That is because mame starts numbering buttons at 0 instead of 1
wooowman93
« Reply #6 on: August 25, 2010, 09:55:31 pm »
its just that only button 16 changes to 15 and every other button stays the same
wooowman93
« Reply #7 on: August 26, 2010, 08:19:38 pm »
please help
bkenobi
« Reply #8 on: August 26, 2010, 09:58:32 pm »
Did you try my suggestion?
wooowman93
« Reply #9 on: August 26, 2010, 10:03:54 pm »
i did... over and over again
ragnar
  • Last login:August 16, 2022, 10:40:56 am
« Reply #10 on: August 27, 2010, 12:10:01 am »
Is this a new problem or is this a first time configuration type issue?  If it is a new problem, what did you change recently?
MY FIRST BUILD:
wooowman93
« Reply #11 on: August 27, 2010, 01:53:18 am »
first time config
WhereEaglesDare
    • My HomePage
« Reply #12 on: August 30, 2010, 07:39:03 am »
delete all of MAME files, except roms of course, and reinstall it with a fresh copy.  Go into MAME and hit Tab and reprogram your inputs with your CP.  Escape out of MAME and go back into it and see if it changed again..
wooowman93
« Reply #13 on: August 30, 2010, 08:51:55 am »
sorry i figured out the problem it was with mame and how it view the gamepads buttons and i just ended up rewiring to another input.
