Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: FM Towns / Marty in Maximus Arcade Tutorial  (Read 4802 times)
nickynooch
  • Moderator
  • Last login:July 25, 2019, 02:54:37 pm
« on: August 16, 2010, 01:20:11 pm »
From the old forum originally posted by M37R01D
Well I've been playing around with UNZ which is a FM Towns / Marty emulator.
The emulator is deff pretty solid and runs just about everything I tried on it.
Next was trying to get it to work in Maximus.
Basicly the emulator needs the image file to be mounted with deamon tools to boot up.
To achieve this I used the Chankast_launch files and modified the .ini a bit to route to UNZ.exe
Then I cleaned the settings in MA for dreamcast, and set the launch exe to Chankast_launch, set my rom directory, and changed the file type to search for .img files.
Only problems I've ran into so far is getting it to open in fullscreen, but I havent played with that much as its prob a simple command. (F11 after launch goes fullscreen)................  so after playing a bit it seems -fs is fullscreen, now just to figure out how to automate it in the launch,
And I have to take out Dreamcast becuase I can't have 2 Dreamcast sections
INI posted below
you can grab the emulator here
http://members.at.infoseek.co.jp/townsemu/unz0510a.zip
you can also grab chankast wrapper here
http://www.gameex.info/forums/index.php?showtopic=2654
Hopefully this system can be added into the emulator list, as really its basicly like DC/Chankast was setup
Chankast_launch.ini
Code: [Select]
[General]
ChankastExe=Unz.exe
Drive=F:
MountTool=DaemonTools
Delay=1
Unmount=True
Exit=27
[DaemonTools]
Exe=C:\Program Files\DAEMON Tools\daemon.exe
Device=0
« Last Edit: August 16, 2010, 01:35:55 pm by nickynooch »
