Author Topic: Time to "KICK" it up a notch  (Read 23250 times)
Spyridon
« on: August 10, 2010, 09:39:36 pm »
Another commission restoration.  This time Bally Midway's Kick.
This one is pretty nice to start with.
(I love having a vehicle that easily fits these cabs inside)
Look how clean that cab bottom is
Nothing to do on the coin door exterior as it is really nice.  Even the original logo plate is in good shape
Inside, however, no coin mechs so I'll need to order a pair
Control panel is decent, but this will get stripped down and repainted.  Once repainted, I'll be sending it off to have the graphics screened onto it just like the original
Bezel is in great shape.  I need to remove it and get a good look at the cardboard cityscape and see if that needs any work.  The monitor is actually mounted on the bottom and reflected up onto a mirror.
Marquee is perfect
From the back, you can see the mirror
Let's look inside...
Original power supply was removed and replaced with a switching power supple.  All AC wiring was completely redone, including adding in a new isolation transformer
An MCR adapter was used to connect the switcher
« Last Edit: August 11, 2010, 08:49:03 am by Spyridon »
Spyridon
Re: Time to "KICK" it up a notch
« Reply #1 on: August 10, 2010, 09:44:24 pm »
Okay, that was the good stuff, now let's take a closer look at what we have ahead of us.
The game has some graphics glitches in it.  Random balloons on the screen, disappearing and reappearing balloons, etc.  You can see some missing balloons in this last letter on this intro screen
Hopefully, pulling, cleaning and reseating the ROMs will fix that.
Game also has a very loud hum.  I've heard this is an issue with MCR cabs, but I'd like to see if there is a way to cut this down a bit.
Next let's take a closer look at the cab.  From a distance it looks great, but upclose, some of the flaws start to show
I'm not 100% decided on the best way to touch up those marks, but I have something I'm working on that may work nicely.
...Stay tuned...
« Last Edit: August 10, 2010, 09:53:49 pm by Spyridon »
Superully
  • Last login:October 06, 2016, 02:48:27 am
« Reply #2 on: August 11, 2010, 10:18:23 am »
i'm looking forward to finding out what that is you've been talking about since i have a couple of cabs with similar "errors" where i'm not quite sure how to fix them.
Paladin
  • Mmmm llamaburgers!
« Reply #3 on: August 11, 2010, 11:30:23 am »
Man, I thought the first pictures were the 'after' shots.  That cab is in amazing condition to begin with.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #4 on: August 11, 2010, 02:52:03 pm »
Great game. Glad you're taking good care of it.
Spyridon
« Reply #5 on: August 11, 2010, 03:50:36 pm »
Yeah, for a cab that was originally silk screened directly on the sides, it is really nice.
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #6 on: August 11, 2010, 09:12:36 pm »
Keep us up to date with how you do the touch ups. I'll be interested in this for my kickman. Also, it sounds like you're aware that Rich is going to be doing screening of the panels at some point. I scanned my panel and it's just a matter of when he can get the ball rolling. Just wanted to make sure in case you were going to get it done some other way. Would hate to see a duplication of effort for no reason.
Spyridon
« Reply #7 on: August 11, 2010, 09:45:49 pm »
Yep, already in contact with Rich.  Just waiting for a response back from him on how soon he can take the panel.  Originally he said he would be ready after CAX so hopefully that is the case.  Thanks for scanning your panel as that is what is making the new one possible.
Level42
« Reply #8 on: August 12, 2010, 06:35:49 am »
He told me he was really busy after CAX.....
Great cab, I just missed a Kickman by a few days....not sure it would be a keeper with my limited space, but I think it's a fun game.
TheShanMan
« Reply #9 on: August 12, 2010, 07:07:17 pm »
No problem at all. I am happy to help Rich, as well as the community, when I have an opportunity to.
Spyridon
« Reply #10 on: August 21, 2010, 03:59:07 pm »
Took the control panel off today to start stripping it down.
My plans quickly came to a screeching halt, as I couldn't figure out how to remove the lighted Kick buttons.  Anyone know how to remove these?  The "nut" won't fit over the extended microswitch holder.
EDIT:  Got the buttons off.  The plastic housing pop right off with the bulb assembly
« Last Edit: August 21, 2010, 04:29:51 pm by Spyridon »
Level42
« Reply #11 on: August 21, 2010, 07:26:47 pm »
Yep, that was what I was going to say: Pull ! :)
FrizzleFried
    • Idaho Garagecade
« Reply #12 on: August 23, 2010, 01:01:31 pm »
Nice looking Kick...
BTW - I had that very same adapter running on my Spy Hunter... and I too encountered some pretty hard-core HUMM noises.   The HUMM dropped in volume considerably when I removed ALL 12v lamps from the circuit... which wasn't going to cut it for me so I simply replaced the switcher/adapter with a rebuild linear PS and the humm all but went away.
Spyridon
« Reply #13 on: August 23, 2010, 02:35:01 pm »
Frizz, thanks for the info.   I'll see if it makes a difference with the lamps removed
FrizzleFried
    • Idaho Garagecade
« Reply #14 on: August 24, 2010, 11:53:53 am »
Don't forget the coin door lamps!  Even just one of those plugged in and out came the hum in my Spy Hunter.
Spyridon
« Reply #15 on: September 05, 2010, 01:44:46 pm »
Removed all the controls from the control panel.  I had to pull out the soldering iron in order to remove the player 1 and player 2 start buttons as the wires were soldered directly to the button.
Panel with everything removed
Then applied a coating of CitriStrip to remove the paint.
After that soaks in for a bit, I'll scrap off the paint.
Spyridon
« Reply #16 on: September 05, 2010, 08:01:25 pm »
Citristrip = Magic
Once I clean up the small bits that didn't come off with the Citristrip it will be ready to paint.
  • Last login:February 20, 2026, 04:34:18 pm
« Reply #17 on: September 05, 2010, 08:23:57 pm »
Seems like a good upgrade (though not original) would be a more durable overlay for the CP, rather than stenciling it...
What are your thoughts on this?
Spyridon
« Reply #18 on: September 06, 2010, 08:12:11 am »
I think on overlay would look pretty ugly compared to the original.  Since this is going to be home use only, it will not get anywhere near the wear and tear it did while on location.  It should last a long time.
TheShanMan
« Reply #19 on: September 06, 2010, 01:29:04 pm »
Agreed. So either you don't mind waiting a while to get it screened by Rich or he hasn't told me that he's ready to start doing these panels. I'm hoping the latter?
Spyridon
« Reply #20 on: September 06, 2010, 04:33:14 pm »
I think he is ready for them.
Havok
« Reply #21 on: September 07, 2010, 02:15:46 pm »
If you really want it to be durable, how about a clearcoat once it's silkscreened?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #22 on: September 07, 2010, 03:00:17 pm »
Seconded. Just a quick glance at the space bar on your keyboard should show why this is necessary.
NO MORE!!
Spyridon
« Reply #23 on: September 12, 2010, 08:32:48 pm »
Used a wire wheel brush on my drill to clean up the spots that the Citristrip didn't take off
Then gave both sides a new coat of paint
Now to let it dry for a few days then ship it across the country for screening.
FrizzleFried
    • Idaho Garagecade
« Reply #24 on: September 16, 2010, 10:33:16 am »
If you're going to have the panel screened... why didn't you get it powder coated rather than painted?
Spyridon
« Reply #25 on: September 16, 2010, 10:50:08 am »
I would love to, but I haven't been able to find a powder coater in the area.
Spyridon
« Reply #26 on: November 30, 2010, 12:56:41 pm »
Finally some news on this...
Special thanks to The ShanMan for providing the scans to Rich at ThisOldGame
Rich than vectored the scans
Art screens were then aligned on the panel I shipped out to Rich
and the screen was created
Add some paint
and Voila...
Next add in the third color
and the final product
Comments from Rich:
Ive had several requests to do these and will have this added to my site later today.
Ill be keeping these screens on hand and the setup is pretty simple so will be able to rescreen these as one offs as they come in.
The panels need to be shipped, striped, painted or powder coated for screening.
and the turn time is 2 weeks.
Panel is being shipped back to me and I'll post more pics when I get it.
In the mean time, check out Rich's website for ThisOldGame.  It's really nice to have someone with this type of talent, equipment and experience helping out such a niche community like ours.  Support his site and buy some products!
For more details on the process Rich went through, read his blog over as COSP
« Last Edit: November 30, 2010, 01:25:51 pm by Spyridon »
rikitiki
  • Last login:January 03, 2020, 01:17:35 pm
    • Custom Arcade Game Printing
« Reply #27 on: November 30, 2010, 01:42:20 pm »
Hey thanks, I guess I need to update my blog I thought this was powder coated-LOL
great paint job BTW.
though I just noticed something is/was that small white copyright text down under the right yellow arrow??
I cant tell for sure and the scan I had couldve just been worn completly off: (
hmmm
Saving the Planet one Game at a time.
www.ThisOldGame.com
Spyridon
« Reply #28 on: November 30, 2010, 01:53:46 pm »
Yeah, it looks like it did have copyright info in that area.  Was barely visible on mine and was most likely rubbed off on most cabs.  You can see it on the flyer.
« Reply #29 on: November 30, 2010, 02:02:40 pm »
+1   :applaud:
TheShanMan
« Reply #30 on: December 07, 2010, 04:20:44 pm »
Glad to help, Spy! I'm pretty sure the copyright text is completely worn out on mine, so I apologize that that was overlooked. I never knew it was supposed to be there. I haven't had my panel done yet. I'm hoping to go watch him screen it in person. ;D
Spyridon
« Reply #31 on: December 14, 2010, 09:00:32 am »
No problem, I doubt that there is an original one out there that still has it.  Mine was barely noticeable.
And besides...look:
Rich just posted this updated shot.  Looks really good.  He did nice work recreating the copyright info.  This should be shipping back to me shortly.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
« Reply #32 on: December 14, 2010, 09:24:28 am »
This is a really great game and that control panel looks fantastic!!!
Happy Gaming!
Spyridon
« Reply #33 on: January 16, 2011, 05:40:20 pm »
Got a package in the mail a few days ago
Looks great and Rich even went back and added the Midway copyright after it was determined that it should be there
Now I can put this guy back together.
Spyridon
« Reply #34 on: February 16, 2011, 11:34:31 am »
Installed the control panel today
It turned out really nice.  Also added a NOS bezel.  This one was different from the one I had.  The one that came with this machine had the instruction cards taped to the back.  This one has them screened directly on the bezel.
and with new bulbs in the Kick buttons
RetroACTIVE
  • Gramps
« Reply #35 on: February 16, 2011, 11:37:03 am »
Boy that looks nice !  :cheers:
Happy Gaming!
« Reply #36 on: February 16, 2011, 01:45:38 pm »
Lookin' sharp!  :)
RayB
  • There's my post
    • RayB.com
« Reply #37 on: February 16, 2011, 03:38:43 pm »
WOW!   :notworthy:
Makes me nostalgic. (Kick-Man is one of the first games I dumped money in as a kid)
NO MORE!!
MythTrip
  • Last login:October 26, 2011, 08:12:28 pm
« Reply #38 on: February 18, 2011, 09:13:32 am »
Wow! What a beautiful looking game.  Thanks again, Joe.
VanillaGorilla
  • Coin detected in pocket
« Reply #39 on: February 18, 2011, 11:36:37 am »
FRIGGIN GAW-JUS! Just like the one we had at our bowling alley! I love how pac man was SOO popular at that point, he was used as a 'guest star' in kick..
