Author Topic: LED-Wiz help  (Read 1734 times)
methodical
  • Last login:July 05, 2012, 07:31:51 pm
LED-Wiz help
« on: August 07, 2010, 09:49:39 pm »
I've got my LED-Wiz all wired up... just using 3 outputs for the RGB Drive to change the color on my trackball. What software can I use to have the LED-Wiz start cycling through colors as soon as the computer is turned on?
Dazz
  • Last login:March 30, 2024, 10:34:39 am
  • HyperSpin Team
    • VPUniverse
Re: LED-Wiz help
« Reply #1 on: August 07, 2010, 10:58:47 pm »
Ledblinky
methodical
Re: LED-Wiz help
« Reply #2 on: August 08, 2010, 12:41:30 am »
I've created an animation with LED Blinky... but am a little confused as to how to have it automatically start the animation when the computer is turned on. Seems to only be settings to run animations when games are selected, etc.
arzoo
  • Last login:April 14, 2024, 11:15:11 am
  • Robots WILL kill you.
    • LEDBlinky
Re: LED-Wiz help
« Reply #3 on: August 08, 2010, 11:04:34 am »
You can create a batch file or vb script and run it from the startup folder. Here's the command to launch LEDBlinky and run the animation:
<path>\LEDBlinky\ledblinky.exe "<animation>.lwax"
Robots will kill you.
Arcade Addiction
methodical
Re: LED-Wiz help
« Reply #4 on: August 08, 2010, 01:36:47 pm »
Thanks a lot :-)
I'll try it out tonight.
methodical
Re: LED-Wiz help
« Reply #5 on: August 16, 2010, 12:48:08 am »
So that worked well, but when I used Quick Sheller to auto-boot into Maximus Arcade, it bypasses the batch file. Any ways around this?
arzoo
    • LEDBlinky
Re: LED-Wiz help
« Reply #6 on: August 16, 2010, 08:32:42 am »
Actually, rather than use a batch file - you should configure LEDBlinky for MA and set the "FE Active Animation".
« Last Edit: August 16, 2010, 04:15:19 pm by arzoo »
Arcade Addiction
arzoo
    • LEDBlinky
Re: LED-Wiz help
« Reply #7 on: August 16, 2010, 04:14:17 pm »
Arcade Addiction
