Main > Project Announcements
50 inch rear pro sit down cabinet and candy cab and sf2 pin.
severdhed:
i'd probably remove the metal panel and trace it onto a piece of wood/MDF so you end up with a wooden template that is the same size as your metal panel. then clamp your plexi to the wooden template and use a flush trim or pattern bit in a router to cut the plexi to shape. then lay your metal panel on top of your new plexi panel to mark the bolt holes and drill them out.
amendonz:
Oh ok, I don't think I want to use the original layout might get a piece of mdf and trace out something new. Thanks for the tips tho mate.
What would be the best idea for removing the art stickers on the monitor sides? Would attacking it with an orbit sander be fine? Might crack into it this weekend.
amendonz:
Not an update, more of a look what I just bought!
amendonz:
hmm when you said addiction i had no idea what i was in for
Rick:
--- Quote from: amendonz on September 15, 2010, 04:18:43 am ---hmm when you said addiction i had no idea what i was in for
The "Play Game At Own Risk" sticker should have been a clue.
