Main > Everything Else
Micro Cab competition (Prizes). DEADLINE EXTENDED
<< < (35/45) > >>
SirPoonga:
I've been searching for th joystick.  I wish some more info could be found.  I found that small ball-top that was posted on here, but you have a minium of 100 per carton.  Eeeeks.
team OBryan:
--- Quote from: SirPoonga on November 01, 2003, 09:59:26 pm ---I've been searching for th joystick.  I wish some more info could be found.  I found that small ball-top that was posted on here, but you have a minium of 100 per carton.  Eeeeks.
I'll  try to get to ACE electronics this week and see if anyone else there knows if they can get some more of these or if they even know where they got it from. Also a quick note about the miniature joystick I used. Be careful if you solder to it. The pins are not suppose to be soldered. They appear to plug into some kind of jack . I soldered to it anyway and the down direction didn't work. After looking at it I realized that when I heated it the plastic melted and the pin shifted to the side and it would not make contact.I reheated it and straighted it and it works just fine now.
microwrx:
How much were they for the box of 100?  Got a link for them?
SirPoonga:
http://www.coinopexpress.com/products/parts/joysticks/Mini_Spherical_Joystick_with_Microswitch_3310.html
Chris:
Those things aren't that mini, according to the dmensions!
The dimensions are 85 x 50 x 112 mm.  If my conversion rate is right, that's 3.4" x 2" x 4.5".  A Happ Ms Pac-Man balltop is 3.6" x 3.15" x 4.26".
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
