May 08, 2024, 08:45:34 am
A Pacman control panel is wood with a metal overlay. The center is cut out with a metal joystick mounting plate.Twisted quarter sells the mountsthis setup wont work for some installs but for my cp, it works because I have a metal overlay over a wood panel.a nice thing with this setup is also that by using spacers you have a little tweak room for setting the shaft height.
Hey Ginsu Victim, did you ever get a chance to try that true4-way? How is it? This is the stick ill most likely buy as long as its decent, which Im sure it is. And also, does it seem like it could go in a 3/4" wood CP without any routering?
Quote from: EvilNuff on August 06, 2010, 08:54:16 amDoes anyone (other than you Randy:)) have a review of the GGG true 4 way? Specifically how does it compare to the JLW? Did not see any in the review forum?It's brand new. He revealed it, I do believe, here first. I'm seriously considering ordering one today.Edit: Just placed the order. Hopefully I'll have a review up sooner or later.
