Main > Project Announcements
First cabinet, currently unnamed (Update 10/19/10: It's Alive!)
Pages: << < (3/6) > >>
martoon x:
Getting close! I think you might be wiring up before the end of the month
GoingIncognito:
I hope so!  ;D
GoingIncognito:
Here's a render of the control panel that I printed out at actual size so that we could overlay it on to the actual control panel to make sure everything is properly spaced.
The top row of buttons are as follows: Coin 1, Player 1 Start, Admin, Player 2 Start, Coin 2.  Not shown are the two buttons mounted on the side of the cabinet for Pinball, etc (they are shown in the renders above anyway).
Yvan256:
--- Quote from: GoingIncognito on August 14, 2010, 12:38:02 pm ---Here's a render of the control panel that I printed out at actual size so that we could overlay it on to the actual control panel to make sure everything is properly spaced.
Just make sure your side pinball buttons are not in the way of anything (left player joystick or right player buttons).
GoingIncognito:
Yeah, the side buttons are far enough away to not interfere with any other controls.  While not pictured in the render just posted, you can see them in the beginning of the thread.  They are positioned closer to the front edge (where you would stand) and down a bit, so they will be "below" any of the other controls anyway.
Next up, decasing the computer bits and mounting to the rear hinged door!
Go to full version
