Main > Project Announcements
"Murdered Out"/ The BlackOut Bartop - Artwork Update
TEKNYNE:
Nice clean build! :applaud: If it was mine I would go with the 1943 (I have most likely dropped a grand into 1943 over the years) or Double Dragon for the second choice as it seems you see less of them, and why have something every one else has? I have a thing against wrestling so mat mania is out for me...
jholman76:
Thanks guys. The artwork and button labels really completed it for me. I have a couple really small hardware things to do, but after that, its all software tweaking.
I fixed my Daphne problem. I just edited the ini file for Maximus and now it all boots just fine. I just with my older version supported -fastboot.
Whats left:
-mount LED strips permanently
-clean up power cables
-tweak software (as I have stated in previous posts)
Future plans
-build 2P box
-PLAY, DANGIT!
I might get a higher CFM fan. The Scythe is really quiet, (in fact I don't even hear it when I have it open) but after a few hours, the heat does build. Its not super hot-but I don't want to have any pop pop pop of the caps.
joe
Rick:
--- Quote from: jholman76 on August 06, 2010, 02:45:45 pm ---Thanks guys.
That is amazingly beautiful in its simplicity. I scanned through the marquee shots thinking you had setup some lcd screen, or rotation system and thought, "OMG that's awesome!!!" But, no. Simply beautiful, beautiful, beautiful marquee artwork. (I'm not panning it - just planting the bug in the ear of the next enterprising modder.)
jholman76:
--- Quote from: Rick Elphinstone on August 11, 2010, 03:04:34 pm ---That is amazingly beautiful in its simplicity. I scanned through the marquee shots thinking you had setup some lcd screen, or rotation system and thought, "OMG that's awesome!!!" But, no. Simply beautiful, beautiful, beautiful marquee artwork. (I'm not panning it - just planting the bug in the ear of the next enterprising modder.)
I have a little LCD, but its only 7" wide so that would look goofy there. Its also a touch screen, so that would be an even bigger waste.
Check this out:
http://forum.arcadecontrols.com/index.php?topic=70840.msg729906#msg729906
thanks for the kind words none the less.
joe
Rick:
--- Quote from: jholman76 on August 11, 2010, 03:36:04 pm ---Check this out: http://forum.arcadecontrols.com/index.php?topic=70840.msg729906#msg729906
Why, that sneaky SOB. LOL.
