Author Topic: For Desktop Only  (Read 1618 times)
mytymaus007
For Desktop Only
« on: July 16, 2010, 11:43:49 am »
Is this a solution for desktop only monitor so i can play vertical and horizontal games. Anyone have this monitor
http://cgi.ebay.com/Dell-UltraSharp-1704FP-17-Flat-Panel-LCD-TFT-Monitor-/120589431135?cmd=ViewItem&pt=Computer_Monitors&hash=item1c13b0b15f
meany
  • Last login:May 01, 2019, 02:12:23 pm
  • Atomic batteries to power, turbines to speed....
Re: For Desktop Only
« Reply #1 on: July 16, 2010, 12:22:04 pm »
I use this monitor at work.  it great when I fire up Mame on my lunch hour.
OverRide
  • Last login:May 04, 2023, 08:06:52 pm
« Reply #2 on: July 16, 2010, 12:25:57 pm »
I have an HP monitor that has the same feature. It is great for mame.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: July 16, 2010, 12:27:28 pm »
They are some nicely priced HP LP2065's on ebay. They are awesome. Great viewing angles and, as you wanted, they also rotate.
extendedplayarcade
  • The Games You Crave
    • Extended Play Arcade
« Reply #4 on: July 16, 2010, 01:01:30 pm »
another option is getting a 24 inch monitor you are able to wall mount with this
http://www.amazon.com/VideoSecu-Adjustable-Rotating-Monitor-Screen/dp/B001L4AJDW/ref=sr_1_2?ie=UTF8&s=electronics&qid=1279299394&sr=8-2
Rotating it for a wall mount vertically for pinball action too.  Just a thought or what I was thinking.
gryhnd
« Reply #5 on: July 16, 2010, 01:24:24 pm »
geeks.com always has a bunch of rotating monitors as well. They happen to have a 20" HP for $95 right now, but also similar 17"s.
Completed: No Name Upright
Ginsu Victim
« Reply #6 on: July 16, 2010, 01:27:07 pm »
I wonder why they call it 720p in the description. It's a 1600x1200 max resolution (I'm using one right now).
DillonFoulds
« Reply #7 on: July 16, 2010, 06:57:34 pm »
720p = 1280x720 or 1366x768
Both resolutions comfortably fit within the 1600x1200 boundaries. I'm guessing that the monitors will letterbox some black bars onto that picture to fill the 1600x1200, yes still natively display the 720p advertised.
