Main > Everything Else
A word about Dropbox
<< < (2/4) > >>
shmokes:
--- Quote from: pinballjim on July 15, 2010, 05:04:52 pm ---I personally try to keep my piracy a little more anonymous....
A little more anonymous than what???  It's a thousand times more anonymous than bit torrent or even newsgroups.  It's actually not a very good tool for piracy for the same reason.  It's only good for sharing with people you know and you're limited to the upload bandwidth of that person (as opposed to distributed bandwidth you get with bit torrent).  Just don't share copyrighted material with people you don't trust.  Publishers can't see what you're sharing and then get a court order to have your identity revealed.
shmokes:
--- Quote from: AtomSmasher on July 15, 2010, 05:03:22 pm ---
--- Quote from: RayB on July 15, 2010, 04:53:14 pm ---how is the syncing handled? Do you have to install software that keeps a background process running all the time?
Yes.  This is my biggest annoyance about it, although it does keep it pretty seemless.  I have the program set so it doesn't start at system startup and only turn it on when I'm working with the dropbox stuff, which works pretty well.
With that said, it's tiny, unobtrusive, extremely stable (I have not once had it crash or cause a crash in two years) and its resource usage is invisible.  It may as well not be running.  And, of course, not running it is an option.  It's just not an option I find worthwhile.  There are VERY few programs I would say that about.
AtomSmasher:
--- Quote from: shmokes on July 15, 2010, 07:45:08 pm ---
At 40mb of memory usage at all times, it's hardly tiny, but I do agree with unobtrusive, stable, and minimal cpu usage.
javeryh:
Wow this is a good way to share music with friends.
jimmy2x2x:
Very useful, I use mine as a backup device.
Thanks for the headsup!
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
