Main > Main Forum
beginner needing help converting Jamma to MAME.
Pages: << < (3/3)
BobA:
The monitor will use your current card at 31k.   You might want to try out soft15 to get lower res and play your games at their original settings.  Don't want to get into a discussion of what looks best as the argument for and against can go on forever.   It is your personal taste that will dictate how you want to view the games.
dfg:
--- Quote from: BobA on July 15, 2010, 09:04:02 am ---The monitor will use your current card at 31k.   You might want to try out soft15 to get lower res and play your games at their original settings.  Don't want to get into a discussion of what looks best as the argument for and against can go on forever.   It is your personal taste that will dictate how you want to view the games.
well look im not really too fussed if its not 100% exact arcade look but if the 8500gt, will run on this monitor using this soft15 program id be happy with that.  but if its really a big headache to get it working without the ArcadeVGA 3000 then im happy to invest in one of these.
BobA:
At 31k it will work as soon as you plug it in without even the soft 15 program.   It is only required if you want to use the real arcade resolutions of your monitor.
dfg:
--- Quote from: BobA on July 15, 2010, 10:32:56 am ---At 31k it will work as soon as you plug it in without even the soft 15 program.   It is only required if you want to use the real arcade resolutions of your monitor.
ah k so it shuld run with that current card. how about the power situation? would i just connect the cab and pc separate (2 plugs) or combine them?
BobA:
Usual easy solution is to use a smart power adapter.  PC is  plugged into the control plug and everything else turns on when the PC does.
Pages: << < (3/3)
Go to full version
