Author Topic: help with guncon  (Read 1961 times)
tykenfitz
  • Last login:January 16, 2020, 02:52:53 pm
help with guncon
« on: July 11, 2010, 01:05:11 am »
OK so, I'm trying to hook up my cypher games guncon for use with MAME.  I tried using guncon2pc but it didn't detect my gun.  Then I used WinGun and it made the gun work good as a mouse in window but in mame the gun sticks to the sides of the screen and in HOD it is jumpy and won't move much,  It's plugged in with the usb and I've got s-video coming out of my pc to a composite adapter which the composite thing on my guncon is connected through.  Does this video set-up create problems?  Do I need to get a new gun con, cuz this one sucks anyway.
By the way I'm using a panasonic 25" crt tv.
Thanks for your help.
Die Hard Arcade conversion to RetroPie
tykenfitz
Re: help with guncon
« Reply #1 on: July 11, 2010, 10:46:52 pm »
OK so I got the gun working HUGE thanks to chrisl for the settings need to the mame.ini file :notworthy:
 but now I cant get games that use offscreen reload to work, is there a way to hook up a button
( I have a pedal I use for time crisis)  to make the gun reload instead oof actually shooting off screen?
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
« Reply #2 on: July 12, 2010, 02:28:53 pm »
Whos Chris? I need that kind of help too
Mine works fine as a mouse in Windows but not at all in newer versions of mame
My MAME Build:
tykenfitz
« Reply #3 on: July 12, 2010, 07:49:02 pm »
I'm using Mame 129
and WinGun with these settings, the only guncon game working at an "OK" state right now is point blank, the others don't track the gun well at all for some reason.
Gun 1
Tigger=mouse button 1
clip button=mouse button 2
Gun 2
Trigger=mouse button 3
clip button=mouse button 4
In mame 0.129
# CORE INPUT OPTIONS
coin_lockout              0
ctrlr
mouse                     1
joystick                  0
lightgun                  1
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            lightgun
pedal_device              keyboard
dial_device               keyboard
trackball_device          mouse
lightgun_device           lightgun
positional_device         keyboard
mouse_device              mouse
dual_lightgun 1
bkenobi
« Reply #4 on: July 13, 2010, 12:42:52 am »
The drivers are calibrated for a specific resolution.  If you change resolutions, the gun won't move the mouse correctly on the screen which will result in funky behavior of the gun crosshair in MAME.
tykenfitz
« Reply #5 on: July 13, 2010, 10:21:16 pm »
I thought that might be a problem, should I adjust my desktop resolution to the one that I play the game with the most?
Can I recalibrate it with each game?
Thanks man.
Derrick Renaud
  • Last login:March 30, 2018, 11:06:19 am
« Reply #6 on: July 14, 2010, 08:27:17 am »
IIRC, WinGun does not work properly.  It can not create 2 independant mice.
Use Guncon2:
xoomer.alice.it/guncon2/
bkenobi
« Reply #7 on: July 14, 2010, 10:55:24 am »
Wingun does not create 2 mice if I remember correctly, but you can use it in MAME anyway.  You cannot use it in "mouse" mode though.  If you use "lightgun" mode, the position of the cursor is set each time a trigger is pressed.  I have not had any luck getting my Guncon 2's to work with MAME (non-custom compiled) for quite some time.  I have either custom compiled to remove the RAW input system or used MAME 0.117.
If you have a Guncon 2,  you need to use the Wingun driver as the other linked driver does not deal with the rolling x issue (or whatever it's called).
tykenfitz
« Reply #8 on: July 14, 2010, 10:11:19 pm »
Thanks guys. I'l try using 117, but do I need to get the old roms to use it?  I'll try it later I'm replacing the sticking trigger microswitch in the guncon right now.  :angry:
bkenobi
« Reply #9 on: July 15, 2010, 02:08:16 am »
You can rebuild your set with CMP.  The other option is to check what gun games have been updated/added since 0.117.  I think I used to have a list, but since I've upgraded to a newer version, I probably don't have it any more.
