Author Topic: Jamma Harness  (Read 943 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
Jamma Harness
« on: July 07, 2010, 01:01:16 pm »
Can you cut off the wires you dont need! too many wires like a bt phone box lol
Franco B
Re: Jamma Harness
« Reply #1 on: July 07, 2010, 01:33:26 pm »
You could chop them off if you really wanted to.
What happens if you do chop them off and you decide to play or test a PCB that uses more buttons etc?
I just cable tie them in a ring to keep them out the way but still available if required.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Jamma Harness
« Reply #2 on: July 07, 2010, 02:44:32 pm »
+1
There is nothing worse than going to add a button and finding that somebody snipped the harness.  :angry:
Working: Not Enough
Projects: Too Many
Progress: None
Ken Layton
  • Guru
  • Technician
Re: Jamma Harness
« Reply #3 on: July 07, 2010, 03:41:42 pm »
Yes, coil up the extra wires in a loop and secure wire wire ties.
Don't chop them off!
« Last Edit: July 07, 2010, 03:44:14 pm by Ken Layton »
Darren01274
Re: Jamma Harness
« Reply #4 on: July 07, 2010, 03:55:14 pm »
Sussed it now just followed 60 in 1 manual instead of the pinout from the place where i bought it all up and running
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re: Jamma Harness
« Reply #5 on: July 07, 2010, 06:51:06 pm »
coil them up and cable tine/tape them up
suggest you also insulate the ends if the wires are bare - to avoid any unexpected short circuits!
