Author Topic: Best software to encode DVDs?  (Read 1038 times)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« on: July 05, 2010, 08:14:43 pm »
I'm add going to add a few a movies to my cab, yes I know a cab shouldn't have movies.
Anywho, I used dvdencryptor to rip a dvd, how can I convert it to an AVI? I think it's called encoding software.. not sure.
« Last Edit: July 06, 2010, 02:22:05 am by shateredsoul »
Kevin Mullins
    • Me on Myspace
Re: Best software to I'mencode DVDs?
« Reply #1 on: July 05, 2010, 11:58:30 pm »
I was just going through the same thing as was tipped off to try DVDFab ..... friggin' does an awesome job. Lots of options to play with.
Another is ImTOO DVD Ripper, but I have only played with it a little bit. Result size was smaller, but I was having quality issues on the couple I tried. YMMV
shateredsoul
Re: Best software to encode DVDs?
« Reply #2 on: July 06, 2010, 02:24:56 am »
I tried autogk.  It gives you an option of how well you want the quality to be preserved.  I put 100% and i could definitely tell the quality was not so great.  My resolution is set to 1920 x 1200 so it's really easy to notice the quality downgrade.  Someone suggested just making ISOs but man do those take up a lot of room.
Do you know if there is anyway to make an ISO or movie file that preserves dvd quality but gets rid of extras? maybe that will decrease the size.
  • Last login:Yesterday at 03:22:36 pm
« Reply #3 on: July 06, 2010, 05:19:08 am »
I use http://sourceforge.net/projects/megui/ but I don't do .ISO files, only .mkv ones.
Raitsa
  • Last login:March 29, 2024, 10:45:35 am
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #5 on: July 06, 2010, 07:45:44 am »
DVDShrink always ripped effectively and lets you choose what you rip. Encoding to/from DVD to another format will always present problems though and I was surprised when I was doing it how many programs produced flawed results.
shateredsoul
« Reply #6 on: July 06, 2010, 02:51:48 pm »
so I noticed that even when it's running the movie straight from the DVD it's a bit pixelated.. does this mean my monitor is too high res for dvds? Any suggestions on Blueray Software?
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
« Reply #7 on: July 06, 2010, 03:30:33 pm »
I use ConvertXtoDVD4 really good and quite fast too  :)
bpark42
  • Last login:July 11, 2015, 03:55:08 pm
« Reply #8 on: July 08, 2010, 11:59:44 am »
Handbrake is your friend.
http://handbrake.fr/
It has a learning curve, but it the best program I have ever used for re-encoding.  I encode high profile x264 in .mkv containers and the file sizes usually work out around 1.7 gigs for a 2 hour movie.  It is generally near-impossible to tell a quality difference from the original dvd...and this is from a 1080p projector on an 8-foot wide screen in my theater.  :)
Feel free to message me if you need some help with settings.
Oh, and if you try this on your own and you use the Constant Quality setting, do NOT use 100%.  Go with something in the low 60's, like 63% maybe.  Personally I find constant quality flaky regardless, so I use good old fashioned constant bitrate (1800 generally).
EDIT: forgot to mention that handbrake will remove all the extras/junk
« Last Edit: July 08, 2010, 12:01:32 pm by bpark42 »
