Author Topic: Help designing a MAME Bartop (Edit: found a free stand up cab!)  (Read 2421 times)
tykenfitz
  • Last login:January 16, 2020, 02:52:53 pm
Hey guys I really want to build a bartop cab but I had a couple questions.  First off, do you think I think I should use a CRT monitor?  I think it would work great because they're very cheap and plugs right into the pc running mame.  Are there any good plans for a crt bartop? (I'm not very good and designing plans would be great, I could definately alter them slightly though.  Also do you think I should go with a 2 player set up, because it might be kind of squished I was thinking either like 2 joystick and 4 buttons per stick or just one joystick and about six buttons for mortal kombat and the like buy then you  ouldn't go head to headd  :dizzy:
Thanks for your help guys!
« Last Edit: July 05, 2010, 11:04:05 pm by tykenfitz »
Die Hard Arcade conversion to RetroPie
  • Last login:May 06, 2024, 04:33:26 pm
Re: Help designing a MAME Bartop
« Reply #1 on: July 01, 2010, 10:20:03 am »
I've made a CRT bartop before, basically a mini Pacman.  It was very heavy, due to the weight of the CRT.  I don't have any plans though, I just kinda winged it.   :cheers:
BobA
  • What Me Worry?
« Last Edit: July 02, 2010, 02:09:10 pm by BobA »
tykenfitz
« Reply #3 on: July 03, 2010, 12:20:32 am »
Thanks for the Plans!
t0mbi
  • Last login:October 20, 2010, 11:59:10 am
« Reply #4 on: July 03, 2010, 08:08:49 am »
I have a 20" LCD in my bartop...and 2 player controls and it isnt really crowded. it works fine :)
In the pic, i have a 15"..its a old picture lol
tykenfitz
« Reply #5 on: July 03, 2010, 04:49:37 pm »
what kind of joysticks are those? are they physically restricted to 4 way?
t0mbi
« Reply #6 on: July 04, 2010, 03:20:08 am »
They are Zippy. and they are 8 way, but i can change it if i want, which i wont lol
tykenfitz
« Reply #7 on: July 05, 2010, 11:02:48 pm »
Just found a free arcade cab on Craigslist, I'm gonna pick it up tomorrow and just try to do a conversion.  I don't know anything about the cab except what's in this pic and that it's free  :cheers:
Really weird picture I can't even tell if it's got a monitor or any controls on the cp  :dizzy:
Smoker
  • Last login:December 12, 2011, 09:08:37 pm
Re: Help designing a MAME Bartop (Edit: found a free stand up cab!)
« Reply #8 on: July 29, 2010, 03:05:25 am »
Thats a Die Hard. from that pic its missing the monitor and the mounting cage. It has the coin slots on the top of the control panel, and a standard 8way 3 button layout for each player with plenty of room to add a second row. Without the monitor and floor plate attached it is really light and easy to move. the whole cab is made out of vinyl. the hardest part is going to be mounting a crt.
If you go with an lcd you can just pick up a flexible lcd mounting arm and attach it to the top of the monitor area underneath the marquee area.
