May 08, 2024, 08:12:50 am
Can you still buy AT's?
Quick answer, bridge pin 14 to GND.Long answer [here]
Just use a PC power supply and hook up your LCD to the board's PC monitor output.
Quote from: RayB on June 30, 2010, 06:29:51 pmJust use a PC power supply and hook up your LCD to the board's PC monitor output.Hey wait I thought you can't just use an LCD with a jamma board? I thought the 15hz to lcd/pc monitor won't convert, and you need a rga to vga adapter?
