May 08, 2024, 10:23:26 am
I made a sheet metal control panel before with all low-tech tools, no lasers or anything space-age1. A corded jigsaw with appropriate blade can cut the panel out (mine was shaped like a rectangle)2. Pilot-point drill bits and a corded drill can make the carriage bolt holes3. A radio chassis punch can cut 1 1/8" holes for buttons and sticks - I used chainsaw lubricant oil when using this.4. An angle grinder to clean up the edges (maybe)The punch works like this :Mine was Greenlee Radio Chassis Punch #730, 1 1/8", I see them on eBay sometimes(those aren't my pics but mine looked like that)Working with metal is like 100 times slower than working with wood, but it can be done and it's not hard or expensive Quote from: bkenobi on February 26, 2010, 03:28:21 amFind a metal shop. They can cut the CP in about 2 seconds and should only charge you a few $ for the effort... Hey that's a good idea Have fun!Craig
