Author Topic: Modelling material for cabinet shell models?  (Read 2530 times)
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« on: June 29, 2010, 12:51:59 pm »
I'm looking to create some rough scale models of our product range for taking to shows etc. but I'm struggling to think of a cheap, rigid material that won't require loads of time to put together and won't crush or damage easily.
See I could do them in wood but that would take too long, whilst normal card will be too flimsy. I have looked at corrugated plastic sheets but they are very pricey. Can anyone suggest a lightweight tough material that would work?
newmanfamilyvlogs
    • Newman Family Vlogs
Re: Modelling material for cabinet shell models?
« Reply #1 on: June 29, 2010, 01:20:04 pm »
http://sugru.com/
Might not be exactly what you're looking for.. but it's a remoldable plastic-y material.
Edit: Somehow I read 'rough' as being a smaller scale. Thus this material is wholly inappropriate.
« Last Edit: June 29, 2010, 01:58:06 pm by cotmm68030 »
BobA
  • What Me Worry?
« Reply #2 on: June 29, 2010, 01:32:04 pm »
Baltic birch plywood is used very often for mini cabs and models.  It is thin and has more layers then regular plywood.
Baltic Plywood
Turnarcades
    • Turnarcades
« Reply #3 on: June 29, 2010, 02:07:58 pm »
Thanks for the suggestions, but these are a little more involved than I need. They aren't proper scale models; they will just be made to the overall scaled shape of the cabinet to give people an idea of the various cabinet proportions, without the need to build a whole rack of demo machines that we may not have room for. I want to build a few about a foot high, but ideally I need something more craft-like that can be cut with a sharp knife or similar rather than tools, and be put together with a glue gun or staples or something.
Bender
« Reply #4 on: June 29, 2010, 02:12:46 pm »
foamboard or gatorboard would work although sheets that big get a bit pricey
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #5 on: June 29, 2010, 02:23:25 pm »
I used foam board for a small cab mock-up and I think it's probably what you're looking for.  I don't know where bender is buying his but the stuff I found was really cheap.
  • Last login:Yesterday at 12:07:27 am
« Reply #6 on: June 29, 2010, 10:21:04 pm »
Artboard or foamboard as its also called.  Light, rigid easy to cut and perfectly smooth.  That would be my choice. It is available in various colors as well though usually in either black or white.
Bender
« Reply #7 on: June 29, 2010, 10:27:19 pm »
I was under the impression he wanted to make full size mock ups which would require 1/2" foamboard in at least the 40x60" size, that stuff starts getting Pricey!!!
and a 4x8' sheet :dizzy: crazy cash let me tell you, I've had to buy a couple
Turnarcades
    • Turnarcades
« Reply #8 on: June 30, 2010, 08:31:53 am »
Foamboard probably is the best solution, though I will have to check suppliers as the place I usually go for mountboard only has single-faced foamboard (ie. card front with foam backing, but no reverse card face). This should do the trick nicely - thanks all.
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #9 on: June 30, 2010, 10:51:53 am »
i 2nd this, i work with foamboard at work all the time. the .25 inch stuff works great, is rigid, and is easily cut-able with and exacto and ruler.
gator board is even more rigid but a little harder to cut/work with in my opinion.
both can be spray painted if needed
gnateye
    • natty's arcade
« Reply #10 on: June 30, 2010, 10:53:54 am »
we get ours from dickblick.com or artmart.com comes in 4 foot by 8 foot pieces just like plywood. all thicknesses from .125" to 1 inch.
« Reply #11 on: June 30, 2010, 12:21:01 pm »
I've not tried it yet but my wife suggested I use 4x8 sheets of foam insulation for my mockup. It seems to be cheaper than foamboard.
Blanka
« Reply #12 on: June 30, 2010, 12:31:56 pm »
Browse the IKEA for some cheap-ass table surfaces or so. They are king of hollow paper-sandwich panels. Ever stumbled over a LACK table? Did it survive?
You can buy the board in plain format too, but no idea where. The Design Acadamy runs on this stuff for study models.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #13 on: July 01, 2010, 08:13:27 am »
I made my PocketGalaga from berch plywood. It's lightweight and sturdy. I simply glued the thing together.
Bender
« Reply #14 on: July 01, 2010, 12:57:25 pm »
Ahh I should lean to read better he clearly states a scale model in the first post :banghead: :banghead:
yeah regular foamboard is the way to go!
and would be really cheap for a scale model
newmanfamilyvlogs
« Reply #15 on: July 01, 2010, 01:43:01 pm »
I think all the confusion is stemming from a misunderstanding of the word 'rough'.. As is it the model that is to be rough, not the scale.
I'd parse 'rough scale' as meaning close to 1:1, but not quite.
Turnarcades
    • Turnarcades
« Reply #16 on: July 01, 2010, 09:37:48 pm »
The models will be just scaled down to about 1/6 but will not replicate all the fine points like edge lips, control panel detail or anything. They will just be basically like creating a cube out of paper using a folding template (OK a little more detailed than that) and then lined up on pivoting pins along a 4 foot baseboard. This will sit on the table of my trade stand and be used to demonstrate cabinet size differences to visiting customers and can be turned round without being nicked. Something like this:
Trap
  • Last login:November 07, 2015, 12:22:32 pm
« Reply #17 on: July 02, 2010, 12:20:28 pm »
I made this from some 1/16" birch ply.  I cut it out with a laser cutter we have at work. It took less then an hr to cut it out and glue it together.  Worked well I thought.
jholman76
« Reply #18 on: July 02, 2010, 12:57:08 pm »
Contact your local mad scientist and borrow his shrink ray.
i am not kidding.
