Author Topic: Power Stone 1 and 2  (Read 2149 times)
runback22
  • Last login:January 28, 2014, 12:21:05 pm
Power Stone 1 and 2
« on: June 28, 2010, 10:45:29 am »
Are these available for mame and if so, how do they run?  I have a 1.86ghz core 2 duo with 2 gigs of ram and an Nvidia 8800gt graphics card.
I thought about buying a dremcast to play these....I also started looking into NullDC.....As far as Null, does anyone know how well those play and how
difficult it is to get it to work.....
DashRendar
Re: Power Stone 1 and 2
« Reply #1 on: June 28, 2010, 11:11:30 am »
These play great on NullDC.
Gatt
  • Last login:February 04, 2020, 08:24:38 pm
« Reply #2 on: June 28, 2010, 11:15:31 am »
Unplayable in Mame on 2.8ghz C2Q and 4 gigs of memory in 138.
SlayerAlex
  • Last login:September 17, 2011, 09:19:27 pm
« Reply #3 on: June 28, 2010, 11:15:56 am »
you mean dreamcast or arcade version? I know NullDC was comming along well with Atomiswave arcade emulation, but i havent been keeping up with that.
runback22
« Reply #4 on: June 28, 2010, 11:33:26 am »
how difficult is it to set up Null DC and would by specs above allow me to play these without lag?  Is it comparable in setup to psxe?
DashRendar
« Reply #5 on: June 28, 2010, 11:38:44 am »
Dreamcast.
As far as how hard it is to set up, it depends on your front end.  I'm using HyperSpin, which took a little bit of configuration to get NullDC to work right (but it works great).
As far as setting up NullDC itself, it's not difficult.
raungst
  • Last login:October 14, 2016, 03:05:40 pm
« Reply #6 on: June 30, 2010, 11:27:53 am »
I have a 2.1 GHz c2d and power stone 1 and 2 work great. Development has ramped up recently on nullDC. They seem to be making a lot of progress. It's much more polished and stable than 1.0.3 was. (http://code.google.com/p/nulldc/) I'm not sure how to set it up in Hyperspin, but I have it working great in MaLa. I assume its very similar.
Warborg
  • Last login:March 28, 2024, 12:41:41 am
  • Personal text? Nah...
« Reply #7 on: June 30, 2010, 02:11:18 pm »
Alas, it's not that it's ramped up, he released what he had to this point because he is discontinuing development...  :(
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #8 on: June 30, 2010, 02:37:29 pm »
actually since he did that there's been bout 2 or 3 more releases (he said he discontinued, but he's definitely still working on it).  Check the google code pake and the issues people have reported.. you'll see his responses to these reports.  They recently released revision 50.  Works really well. I'd say about 80% of the games I have tried run fullspeed.
