Author Topic: Disc Of Tron, Spinner Configs  (Read 1799 times)
H4CK3R
  • Last login:November 16, 2012, 06:12:09 am
« on: June 26, 2010, 03:20:59 am »
Tring to play some Disc of tron, but mame doesn't see the spinner up and down motion.  It works in notepad, I can select things on my desktop, ect... But Mame doesn't see it... any idea's?
Jon-zing here...
DashRendar
Re: Disc Of Tron, Spinner Configs
« Reply #1 on: June 26, 2010, 09:59:31 am »
With a push-pull spinner, doesn't the up/down in DOT register as an analog right click/left click?
Make sure it is set that way in MAME.  You might also need to configure MAME to use Multiple Mice.
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #2 on: June 26, 2010, 11:43:27 am »
It would register as a digital (on or off) input as it used switches, right?
H4CK3R
« Reply #3 on: June 26, 2010, 09:44:45 pm »
I set it up to see multi mouse in the ini file, tho it still doesnt reconise up/ down, right click, left click...
what am I missing?
H4CK3R
Lilwolf
« Reply #4 on: June 29, 2010, 06:20:00 am »
I'm assuming we don't have to ask but...
you don't use the up/down until like level 8 or 9.  Your not testing on level 1 are you?
DashRendar
« Reply #5 on: June 29, 2010, 10:11:58 am »
Isn't there a tank game that uses a push-pull spinner as well?  That might be better to test on.
isucamper
    • my project arcade blog
« Reply #6 on: June 29, 2010, 01:03:53 pm »
What he said.  The game will tell you when you can start using it.  It's actually quite epic.
THE SYSTEM          Popeye
