Main > Main Forum
U360 - Best way to tighten joystick?
I/O:
--- Quote from: Franco B on June 29, 2010, 07:33:37 am ---Which is a more complex solution than just using a screw driver in this situation.
Only if you want to take off the PCB to get at the bottom of the shaft.
Franco B:
Yes, and guess which tool you use for that?
But meh. What works for you, works for you.
Ginsu Victim:
--- Quote from: I/O on July 01, 2010, 09:24:31 pm ---
OH NO! Four plastics nuts I have to remove with my fingers!!! ::)
I/O:
--- Quote from: Ginsu Victim on July 03, 2010, 12:52:59 pm ---
I could be stuffing more fries in my mouth in the few mintues it takes to do this maneuver you suggest.
nickynooch:
I had the exact same problem, I emailed the ultimarc guys they responded to use plumbers tape.
Worked like a champ. Haven't had a problem since. It's a great cheap solution.
Just wrap it around the groove on the stick part where the top screws on. (You'd probably just figure it out). I highly recommend that method.
