Main > Project Announcements
Space Invader Taito Table Top Restore Help Needed
Darren01274:
Found them yes meter readings of them all?
saleem:
then i seriously doubt its power related.
sometimes if you dont know what your doing its best to get them repaired by someone who does.
Darren01274:
How much would new Space Invaders Boards be for this? and where could the boards be repaired and what would the aprox cost be. Is it worth repairing or just go with the 60 in 1 Jamma and LCD Screen?
saleem:
noone can realy quote you the repair,its a case of haing someone look at them,if they know exactly what is wrong thenm they can quote you based on that,or it ends up being a case of,they fix one thing and find out the next thing in line needs repair/replace.so they bill you at the end.
as for replacement boards? you can only look around and shop,ebay,forums etc etc.
i mean,a 60in1 will cost you,the board,the wiring harness as its jamma.the lcd monitor and you will need a switching power supply i would think.i dont think the current transformer will do,unless i am wrong and it can be used.ontop of that,you will end up having to replace both sticks to 8 way ones and you will need idealy 3 buttons although you might get away with 2.
i might be able to help to a certain degree,as i have 2 magsticks and many buttons and microswitchs.if you went mame,i have a minipac and harness.
so if you need a couple of good sticks and buttons i got some for sale.
Darren01274:
I set my other cocktail cabinet up for mame running mala frontend and the new version of mame it was the USA cocktail type. Would have kept that played really well but too big for house really. Was thinkng of making this one a mame but the 60 in 1 sounded less hassle also you can use ATX power supply with the 60 in 1 which I already have.
Bit gutted about not getting it to work :P-( lol
