Main > Everything Else
In-pool umbrellas?
lilshawn:
not to bash you or anything, but have you talked to someone at a pool supply store or a company that builds in ground pools? they probably know what the things in your pool are.
but yes those seem like perfect spots for umbrellas. depending on the socket... i would match the material they are made of. metal and plastic don't really get along.
HaRuMaN:
I was trying to avoid the pool supply / builders as they tend to be way overpriced on stuff like that.
NiN^_^NiN:
Why not of thoese umbrella stands at the edge of the pool that hang and are adjustable
like this one
I've seen ones like that but adjustable were it can lower the umbrella and also extend it out and extra 5ft as well.
Might be an idea cause then it can be used away from the pool too if your just sitting outside
LLUncoolJ:
Sweet pool man, I should've put my bench under the fall. Last weekend was beastly, I could've used something like this too, there is no shade at all until about 4pm in our yard.
On the subject of PVC, I'd go with Sch 80 as well. Regular white PVC doesn't have UV prohibitors in it, so it will become brittle in the sun after a while.
The unbrella NiN^_^NiN posted is pretty sweet, I may look into one of those at some point.
geomartin:
I don't know about the Made in China umbrella. Look at the picture...there is absolutely no shade under it :)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
