Main > Everything Else
Malware troubles
mimic:
I'm also happy to inform that it seems that everything works fine with my xp, thx to the rkill. Encountered few bumps after the rkill, but after updating malwarebytes, everything seems ok now.
As to xiaou2 suggestion of over-install that thought crossed my mind, but I'm afraid that it overwrites reg file and basicaly everything is there, but not associated, I think you can end up with a partial mess.
Xiaou2:
I would never advise an over-install on a system that has a Root-Kit on it, because
it will just rebuild itself.
You have to remove the thing first, and only then can you do an Over-Install.
It will not create a mess. It will repair broken windows issues, and change the
modifications that the root-kit made back to normal.
Afterwords, you will want to re-install all your windows updates & patches.
Be aware, that the 1st thing these root kits do, is to ruin your antivirus programs.
They look like they are running, but they really are not functioning correctly.
You should uninstall them, delete the folder, reboot, then re-install and update the defs asap.
You wouldnt believe the mess these rkits do. Its usually better to just format and
install from scratch.
Daoldman, glad to help. If you have some extra cash, please kindly make a small donation to
"The Dumping Union". They buy the arcade boards that end up in mame.
https://www.paypal.com/us/cgi-bin/webscr?cmd=_flow&SESSION=EtLaGm16CWR_-EUR8fS3s8hMNKXNdaVp4wHQOQTNNHyy4fVYNF2k_csiJLy&dispatch=5885d80a13c0db1f22d2300ef60a6759516e590e949da361fd1b680561e9552a
Navigation
[0] Message Index
[*] Previous page
Go to full version
