Author Topic: Need Some Advice From The Pros  (Read 1349 times)
sstralkowski
  • Last login:July 09, 2012, 03:14:38 pm
  • Rock Out with Macaque Out!
« on: June 08, 2010, 10:22:06 am »
Ok as it is, I have an old Run N Gun as the starting point for my MAME.  But I found another cabinet (Simpsons) with a larger monitor and a better support system for a 4-player CP for fairly cheap.  It's not in great shape, but neither was the Run N Gun.  I'm working on a limited budget and with a very limited skill set here.  If my PC doesn't end up needing a ton of parts to get up to speed, then I could likely afford the new cabinet.  The problem would be that I'd end up with a bunch of extra parts.  So my questions are these.
1) Would it be worth getting the Simpsons cabinet at all or do I have a pretty good base already?
2) Is it fairly easy to get rid spare parts in the event I did buy the two?
3) Would it help me fund this at all or is the demand for the extras I have too low?  I will end up with 2 Marquees, 2 Jamma boards, and an extra cabinet with doors and stuff, and a 19" monitor that has a bit of pink on the corner, plus maybe some other parts.
Havok
  • Trade Count: (+17)
Re: Need Some Advice From The Pros
« Reply #1 on: June 08, 2010, 10:38:40 am »
The Simpsons cab would definitely be a better choice for 4 player. eBay\Craigslist the duplicate stuff; should be fairly easy to sell.
sstralkowski
« Reply #2 on: June 08, 2010, 10:45:45 am »
Would the benefits be worht the $200 I'd be putting out?  Could I recover that perhaps?
Havok
« Reply #3 on: June 08, 2010, 11:05:42 am »
You will most likely not be able to recover that much, but it might be close, depending on what the condition of the parts are (working, cracked, etc)
sstralkowski
« Reply #4 on: June 08, 2010, 12:43:16 pm »
What's the best way to get rid of a spare cabinet?  Will the damage to the front right corner make it pretty much worthless?  It's rounded and a layer of the plywood has peeled off the corner in about a 4"x4" square.
Havok
« Reply #5 on: June 08, 2010, 12:58:25 pm »
Craigslist - you should still be able to sell an empty cab for around $50. If it's too far gone, just list it for free. Once stuff is free, it will go on CL in an instant.
DashRendar
« Reply #6 on: June 08, 2010, 12:59:58 pm »
Bondo that corner, problem solved.
sstralkowski
« Reply #7 on: June 08, 2010, 02:05:54 pm »
If I keep the cabinet for my MAME and don't buy the Simpsons one, that's exactly what I planned on doing.  :)  Thanks for the help guys.  If you can think of any other advice, throw it my way.  This site is an insane wealth of knowledge.  I'm amazed.
kronic24601
  • Last login:June 24, 2014, 03:08:54 pm
  • Evil Arcade Monkey Strikes Again!
« Reply #8 on: June 08, 2010, 02:57:58 pm »
destroy a simpsons cab to MAME it?  :'( that makes me sad
sstralkowski
« Reply #9 on: June 08, 2010, 02:58:38 pm »
Why is that bad?
