Author Topic: Control Panel Thickness...Happ controls  (Read 5391 times)
Jawn
  • Last login:July 22, 2010, 10:21:30 am
« on: June 01, 2010, 04:15:30 pm »
Hello all. I was reading another (very old) thread on CP thickness. From what I've read, 5/8" MDF with 1/8" plexi over it is pretty solid. My question is, will the Happ Super joysticks and Happ Pushbuttons With Horizontal Microswitches fit this thickness?
milkit
  • Last login:June 28, 2014, 09:14:33 pm
Re: Control Panel Thickness...Happ controls
« Reply #1 on: June 01, 2010, 04:27:47 pm »
they are made for up to 3/4" i believe, so yes. you can always route out behind the joystick as well. the pushbuttons probably have closer to an inch
Jawn
« Reply #2 on: June 01, 2010, 05:56:11 pm »
Thanks, just one more question :P So will I need to make any modifications to the CP to fit the pushbuttons in or will they just jut out the bottom more?
Desolis
  • Last login:July 26, 2010, 12:28:59 am
« Reply #3 on: June 02, 2010, 02:45:52 am »
I've used Happ buttons in a couple of arcade sticks I've made already. Mounted in 3/4" board with 1/8" plexi as well. They fit just fine. You shouldn't need any modification at all.
http://2.bp.blogspot.com/_6EMt9kWBw7A/S7bYAZywo2I/AAAAAAAAAGU/2Vwp2uhHOlM/s1600/IMG_0353.JPG
The buttons on the sides are Happ in 3/4" wood.
« Last Edit: June 02, 2010, 02:49:44 am by Desolis »
Jawn
« Reply #4 on: June 02, 2010, 06:38:12 am »
Thanks, I went out and bought 3/4 since they didnt have 5/8. :)
justinjstark
  • Last login:May 14, 2021, 02:20:13 pm
« Reply #5 on: July 09, 2010, 12:40:13 am »
3/4 in plus 1/8 plexi gives you 7/8 inch control panel.  If you a using 3/4 in t-molding along the side you will have control panel sticking out unless you sand it down a lot.  I'd recomment 1/2 inch mdf + 1/8 plexi and let the t-molding hang over the bottom a bit; nobody will be able to notice.
