Main > Project Announcements
First Arcade Cab Project - UltraLux RGB Button Tip!
dawolv:
Playing with the CP again while waiting:
Xmen Design
Xmen Design with CP Base outlined:
Xmen Design with bubbles :D
I think I try putting on the broken laminate pieces today if I get a chance
rablack97:
Nice work so far.
I like # 1. Minus the fact there's a butt staring at you with no face..... ;D
The yellow square doesn't fit on #2, and the speech balloon's are adding more busy to an already busy design.
dawolv:
Yeah your right about the Butt thing, I think there is a joke in there somewhere...thanks for pointing that out!
My Bad, The yellow boxes was meant to outline where the actual 3/4" box borders would be at so it would not interfere with the buttons and wiring.
I think I found a cool sideart piece (School for Gifted Youngsters :laugh2:)
Don:
I think the third CP looks great
dawolv:
OK I got some more laminating done today and Ive learned 2 things about Laminating:
1- Very very brittle
2- Route *AFTER* you laminate :laugh:
I wasnt sure how to mark off measurements and such on the Black Laminate without it being a permanent eyesore.
So I went to Office Depot and grabbed some Chalk (yeah old school chalk), gotta say that worked pretty good. Easy On, Easy Off Daniel-san.
Now what is the best way to get contact cement off of the laminate? Yeah I got a little carried away there.
After inhaling the wonderful fumes from the contact cement I came in and toyed with the X-Mame Cab idea again...
Wilsonart does make blue (the inside of the cab would be black the outside blue with Yellow trim)
I used X-Men Issue number #1 for the CP back ground ;D
Then I say..do I really want an X-Men Theme for a Cab? Dang Fumes
