Author Topic: Jtag Xbox 360. Greatest thing to happen for MAME Cab?  (Read 4910 times)
fallacy
  • Last login:March 23, 2024, 12:27:45 am
« on: May 30, 2010, 12:36:30 am »
Just found out about Jtag Xbox 360 hack. Now on an external hard drive of your choosing you can play every Mame, Nintendo, Genesis, Xbox live, Xbox and Xbox 360 game; on a system that is specifically designed to play games, boots up instantly and you can buy used for around $100.
Is this not the greatest thing to be using for you cabs and not an old computer? You can even bring up video snaps, screen shots and background images for each game. Why has this not been mentioned before on this forum?  :angry:
Demo
« Last Edit: May 30, 2010, 01:21:58 am by fallacy »
SlayerAlex
  • Last login:September 17, 2011, 09:19:27 pm
Re: Jtag Xbox 360. Greatest thing to happen for MAME Cab?
« Reply #1 on: May 30, 2010, 12:59:32 am »
ive heard about it. I think it might be  alittle too new school for most people. But i would defiantly look into it if i ever had a HD widescreen cabinet build. Must be nice playing all those HD versions of old arcade hits. Also isnt it difficult to connect joysticks to the xbox360? PS3 has the Cthulu bored which is like an ipac, but i think the only way with 360 is to hack a pad and soldier yourself. :( too hard for me
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
« Reply #2 on: May 30, 2010, 02:05:52 am »
 :banghead:       :timebomb:        >:(
My MAME Build:
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« Reply #3 on: May 30, 2010, 04:39:04 am »
I hadn't heard of it myself. My concern is that x box 360's are notorious for breaking down.
abzman2000
  • Last login:August 26, 2020, 06:25:12 pm
  • I LIKE my hat!
« Reply #4 on: May 30, 2010, 06:09:27 am »
my friend was given a rrod xbox 360 for free, and for $5 worth of parts we permanently fixed the xbox with this fix, then stress tested it for several hours using red faction guerilla and it works perfectly.  http://www.instructables.com/id/Fix-the-Red-Ring-of-Deathwithout-towels/?ALLSTEPS
Usul
  • Last login:June 12, 2020, 03:44:22 am
« Reply #5 on: May 30, 2010, 09:28:36 am »
Hm, I am actually using the 360 mainly for modern driving games. Never thought of being able to play old-school (driving) games via Mame on it.  So I will give this a shot.
fallacy
« Reply #6 on: May 30, 2010, 11:08:18 am »
Ya the older Xbox360 had a lot of issues; the CD drives would break down the Xbox fan sounded like you had your Vacuum cleaner turned on. I am not sure when but I know the 2009 models they fixed all those issues. They replaced the CD drive the fan is quiet as a mouse. The even added other features like built in hard drive for game saves. Unfortunately  you can not buy a brand new Xbox360 and do a Jtag hack. Microsoft found out about it and with the new dashboard update there is no crack for it yet.
mimic
  • Last login:February 10, 2024, 02:58:45 pm
« Reply #7 on: May 30, 2010, 12:44:21 pm »
As you've mentioned, the problem with Jtag is that you actually need an older xbox, because the hack requires lower version of dashboard and all new xboxs come with newer ver, so you will be stuck with the unreliable hardware.
Also Jtag hack is really hard to pull off, but once you do, it's really sweet. Basically Jtag is the holly grail of xbox 360 hacking
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #8 on: May 30, 2010, 01:45:52 pm »
I thought of the same thing! But then I realized all the trouble I would have to go through to fine the right xbox 360, get someone to hack it, download more games, etc etc...
I currently have ps2 and dreamcast on my system.. an my current issue is choosing between setting up the joysticks to be the control pad or analog stick... there is always a game that uses the control pad instead of the analog stick or only the analog stick and uses the control pad for other functions.  Soooo.. you'd either have to choose to have only xbox 360 games that support analog or the control pad.. or I guess you could eliminate playe 2 and use your second joy..
But yeah, this looks really nice.  I think i'll do it once it gets easier and then I'll figure out how to integrate it into my cp.
Shecky
  • Last login:November 25, 2014, 07:20:22 pm
« Reply #9 on: May 31, 2010, 09:36:31 pm »
My original 360's dvd went out. I then bought an arcade version 360 and held onto my broken one in hope of a hack. About a month after the hack came out I did my research and tried it out. Out of all my previous mods/hacks this one is by far the hardest. I got it to boot up in freeBOOT twice and then Red rings after that. I tried to re-dump the image but nothing. I think my original dump was corrupt and I never got the correct cpu key. So out of anger and burning my fingers 10+ times I ripped out all the wires. I still have my broken 360 and I need to dive back into the scene because I hope they have made it a bit easier. I also dump my original cpu key twice so hopefully they have come up with a way to get a good key from the bad dumps.
I am sure it's a bit easier now, but it sure kicked my cuss. For all your xbox hacking news go here. www.xbox-scene.com
