Main > Everything Else
Any home cooling experts out there?
<< < (2/3) > >>
Blanka:
--- Quote from: patrickl on May 25, 2010, 03:25:00 am ---If you get all that, are you then just gonna say "No, I don't know"?
Do you truly think so?
RayB:
Believe it or not there's no means to close the first floor vents other than by physically obstructing them (which is what I did in winter to help move more heat upstairs).
I've seen window units meant for 1 room for as cheap as $99, btw.
To answer Blanka, lower Canada (Toronto), 1950s building, flat roof, asphalt roll, no attic, insulation unknown, brick exterior, new double pane windows throughout, forced air mid efficiency...  ??
Blanka:
The heat probably comes in through the roof or through the windows then. Brick is usually a good thermal damper. Always best to tackle the source instead of trying to fight the problem with cooling.
So the best bets are:
- Renew roof insulation. Today's insulation is so good, it always pays back on gas-bills if the current insulation of the roof is 10 years or older.
- Add exterior shades to the windows of the top floor.
- Make natural ventilation possible with windows to open. Balanced mechanical ventilation is only interesting for winters if it uses heat recovery from the exhaust pipe.
- AC is NEVER needed, not even in Dubai! We lived without until the 50's, so check building habits before WW2, and there is always a local working solution to fight heat without AC.
RayB:
--- Quote from: pinballjim on May 25, 2010, 09:31:17 am ---Forget costs.  Just think about how good it's gonna feel to lay down spread eagled after a long day and let that cool, cool air from your new window unit wash over your sweaty balls.
  :cheers: RayB likes this.
AC's been running for the last 5 hours now and the top floor is still a $#@?%damn 28C. wtf
Ed_McCarron:
--- Quote from: RayB on May 25, 2010, 04:31:33 am ---I've seen window units meant for 1 room for as cheap as $99, btw.
No you haven't.  You've seen window units meant for one 8' x 8' room in Alaska for as cheap as $99.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
