Main > Project Announcements
Mario Bros Mame Project
nosecondcity:
Well I finally finished last month but haven't had time to post. Here are the rest of the pics.
A few things I learned along the way:
1. this forum is your friend. Your very, very knowledgeable friend.
2. Don't rush ahead to things because you'll pay for it in the long run. For example, after I built the control panel box, I primed and painted it. Then, I drilled and hacked away to secure it on the cabinet. I should have painted it last.
3. When you print out (or have mamemarquees print out) your cpo, don't drill on your cp until you have the overlay. Otherwise, it may not match up exactly (even if you measure and re-measure).
4. Use the correct drill bits. If you don't have the right size, suck it up and buy it or borrow it from a friend. I didn't have 1 1/8" for the buttons, so I used my 1" bit, then spent hours with a file trying to perfectly make a larger circle. I got A LOT of blisters.
5. Prime. I know it's tempting to want your arcade finished and play ready, but priming really is worth it.
6. Make sure all your software/frontend/ipac, etc. is up and running the way you want it before putting everything in the cab. Test your buttons-make sure everything is programmed the way you want it. It's a royal pain after the fact.
7. When you find paint codes on the site here, be careful if it is an old post. I originally was going to use a paint code for Mario Bros Red. However, after having the dude at Lowe's mix the Valspar, he told me the base had changed to magenta. So the end color in no way resembled what I was looking for.
8. MaLa is an excellent frontend, especially if you are using more than Mame (I have Mame, ZNES, and Kega Genesis). All work flawless using a tree so player can easily scroll to what they want to play. I cannot say enough good things about the frontend.
9. I'd highly recommend using the coin reject button as a way to tell Mame you've 'inserted coin'. I was looking for a way to incorporate my coin door without having to use actual coins. A few of the people on the forum had posted about it and I borrowed the idea. I love it and I love the simplicity--very easy to setup (just like a pushbutton).
10. Make sure your cp has space to play. Make a mock out of cardboard or just draw straight on the mdf with pencil to get an idea. It really helped me with spacing.
These are probably pretty obvious things to most people on the board, but I just wanted to share my thoughts. I'm really proud of the way things turned out. Of course, just soon after I finished, I find I have to move out west for work. So now I have to figure out what to do with this since I can't bring it with me.
Anyways, below are the specs:
1. 2 Ultimarc U360s, long shaft, red ball tops
2. 1 Red Ultimarc UTrak
3. Ipac
4. 25.5" LCD monitor
5. HP desktop 250gb, 2gb memory, Intel Pent 4, 8 usb ports
6. Admin buttons-vinyl overlays from Pongo
7. Mamemarquee print outs for marquee and cpo
Enjoy and thanks again to everyone on the board for advice, input, and knowledge!
nosecondcity:
More pics....
emphatic:
Very clever trackball artwork! :applaud:
nosecondcity:
Thanks man. I got the idea after seeing Sardu's control panel pic on the CP database post. I liked how he had pipes on the cp, so I played around a little bit and came up with this.
I wanted to keep the cp original looking, but thought the trackball coming out of the pipe was a good way to make it my own.
WhereEaglesDare:
This cabinet looks fantastic. Did you paint over the old Laminate? Did you have any trouble?
