| Main > Main Forum |
| Received my new panel, but need a little help |
| << < (2/2) |
| syph007:
--- Quote from: lilshawn on May 19, 2010, 02:14:07 pm --- --- Quote from: syph007 on May 19, 2010, 01:49:35 pm ---It's probably bottom mounted right? Top mount instead, it will sit up higher. --- End quote --- ya, if you want to end up on crapMAME. in the humble words of crapMAME: --- Quote ---And of course, exposed plates still suck. --- End quote --- --- End quote --- Top mounted meaning routing a slot ABOVE the wood not below, not exposed mounting plates. Not the same thing. |
| DashRendar:
Right- if you want to bottom-mount the stick, but it's too low on the top side, you'll need to use a router and route out some of the wood so it's higher. Depending on the thickness of the wood will affect how much material you can eliminate. There are numerous threads in the Woodworking forum that talk about bottom mounting (or under mounting) joysticks. Another option, for certain sticks, is to get longer shafts. Ultimarc 360s and Sanwa JLW sticks can both use the long shafts that Divemaster sells. |
| TOK:
I think I did what you want to do... You route a square in the top of the panel and have it sit below the plexi/overlay. I did two other things with mine... I used t-nuts so there are no bolts through the plexi and I also put the dust washer under the plexi. The top of the stick base is sunk down for clearance to do this. There is some debate about the proper installation of the dust washers, and there might not even be a correct way, but I think they look kind of sloppy up top (and conceal the art!). |
| shateredsoul:
thanks for the advice everyone!... I think I"m going to mount it underneath to see how i like it, if I don't like it i'll look into all these options |
| drventure:
+1 on the dust washer comment, I wish I'd routed space for them underneath the formica on the top of my CP. But, in the end, I think I came up with a relatively decent solution, at least for my cab. ;) http://forum.arcadecontrols.com/index.php?topic=88515.msg1073324#msg1073324 |
| Navigation |
| Message Index |
| Previous page |
