Main > Project Announcements
QBert Bartop
TheGameFan:
Does anyone have the sideart with a smaller "black box"?
It is the correct shape, but Coily and the bottom cube are actually supposed to extend beyond the black area.
If not, I guess I have several options:
1) Attempt to fix the artwork myself (although I don't have the vectors, so this may be difficult).
2) paint the entire side of the cab black.
3) Print it as-is and trim the vinyl (which I may have to do regardless).
leapinlew:
Have you considered a single joystick thats switchable? Does the U360 still switch on the fly?
TheGameFan:
--- Quote from: leapinlew on May 18, 2010, 08:43:24 pm ---Have you considered a single joystick thats switchable? Does the U360 still switch on the fly?
Reading up on the U360, it sounds pretty interesting. Overall, it would probably actually be cheaper than two sticks and an I-PAC, plus it would give mouse and analog functionality.
I'm still trying to figure out exactly how it switches between maps though.
Hewskie:
does it automatically through software from what I know, don't own one personally but I think it's pretty easy. If I were to do it all over again, I'd probably use the U360
Hewskie
TheGameFan:
I'm leaning towards the U360. The other thing that concerns me though, is that it's $60 and for the most part doesn't seem to be user serviceable. I like the simplicity of four switches, a shaft and a handle.
