Author Topic: Powering up the pc via coin door lock.  (Read 1564 times)
councilface
  • Last login:June 28, 2021, 05:21:26 pm
« on: May 16, 2010, 05:04:47 am »
Hey all, just wondering if the above is possible (anything is possible - I know!). How would one achieve this? I want to twist the coin door key to power up my pc...
Beretta
Re: Powering up the pc via coin door lock.
« Reply #1 on: May 16, 2010, 05:16:26 am »
possible.. hmm yes,
easiest solution in my mind would be to replace the lock with a electrical kind they use to put on computers to lock the keyboard.
problem is it's a on/off kinda situation.. computers these days only want momentary signal to come on, if the signal is left to long.. like 5 seconds the computer will power off.
i wonder if a reed switch might work.. again still have the constant circuit to worry about..
im sure it can be done but i dont have a ready solution ot offer you just half baked ideas.  :dunno
bkenobi
« Reply #2 on: May 16, 2010, 10:20:07 am »
Here's another option:
http://www.happcontrols.com/driving/50600300.htm
I know that one won't fit, but it's the concept more than the actual item.
EDIT:  This one looks like a better fit...
http://www.amazon.com/Momentary-Key-Switch-2-Keys/dp/B0002ZPBHK
« Last Edit: May 16, 2010, 10:22:01 am by bkenobi »
Thenasty
  • Trade Count: (+17)
  • Online Online
  • Last login:Today at 11:14:40 am
« Reply #3 on: May 16, 2010, 01:31:04 pm »
yeap it's possible. Done it with my CAB long time ago.
Turn the KEY, then turn it back (that was the only way to take key out) so the switch is not CLOSED at all time (or PC will shut off).
Free VGA Breakout Cable
MonMotha
« Reply #4 on: May 16, 2010, 03:25:59 pm »
FYI, you can actually buy key lock switches that are spring loaded momentary kind.  Just hook 'er right up to the "power button" input on any ATX motherboard and have at.  Last time I checked, Radio Shack actually sold these, but that was years ago.
mlalena
  • Last login:June 12, 2021, 12:31:44 pm
« Reply #5 on: May 16, 2010, 08:17:09 pm »
Here's one from ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130307314802&rvr_id=&crlp=1_263602_263622&UA=%3F*I8&GUID=2d9412491280a0b5845341d3fff0ed5a&itemid=130307314802&ff4=263602_263622
Just look out for ones that automatically eject the key after using. (mentioned in the reviews)
http://www.parts-express.com/pe/showdetl.cfm?partnumber=060-216&source=googleps
You might also want to look at simple momentary switches
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260537392617&rvr_id=&crlp=1_263602_263622&UA=%3F*I8&GUID=2d9412491280a0b5845341d3fff0ed5a&itemid=260537392617&ff4=263602_263622
MonMotha
« Reply #6 on: May 16, 2010, 08:49:59 pm »
Most of the round key style ones will probably do this.  Ones that use a standard key probably won't.
