Author Topic: Mounting TV in Cab  (Read 3922 times)
WhereEaglesDare
    • My HomePage
Mounting TV in Cab
« on: May 11, 2010, 04:48:55 pm »
When mounting a CRT TV in a cab is it easier to load it from the front, incase I want to pull it out, or will it be easier to install it in the back and strap it down.
I was thinking of building a type of cage for it so I could load ir thourgh the bezel area with some cloth handles (that will be hidden by my bezel art) and it can rest against this cage I wanna build for it...  What do you guys think?  Does the rear of the TV need to have room to get air moving for cooling or is that less important?
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
Re: Mounting TV in Cab
« Reply #1 on: May 11, 2010, 05:15:29 pm »
arcade monitors are usually mounted from the front or top ( cocktails ) .  build a solid mounting frame depending on the size and weight of the tube. sometimes a plate to rest the chassis is a good idea , makes maintenence a lot easier. if the wires are long enough the chassis can also be screwed on the inner sides of the cab . i would allways advise to take the tube out of the plastic case. the dismantling procedure can be done by a child.
ur new tv to arcade screen doesnt need more room than in its natural habitat , but make sure the heat can get out of the cab . ventilation holes plus fan in the rear or top of ur cabinet prevents breakdowns in hot summer days .
« Last Edit: May 13, 2010, 04:27:23 pm by apfelanni »
WhereEaglesDare
    • My HomePage
« Reply #2 on: May 11, 2010, 05:57:43 pm »
Awesome response!  Thanks, I may need to make some kind of adjustments cuz the screen in it is 25" and the one I wanna put in is 27".  Plus I have to fab some sort of mounting bracket
Beretta
« Reply #3 on: May 11, 2010, 06:34:28 pm »
make sure you have help.. 19's are'nt to bad to handle by your self but a 25 or 27 inch is a hand full.. and very easy to damage if you uncased it.. which i would.
better to have hep and not need it then to need it, not have it and end up with a busted set.
WhereEaglesDare
    • My HomePage
« Reply #4 on: May 11, 2010, 06:52:42 pm »
good advice,
how do you handle the power button?  my set doesnt power on on its own, you have to hit the button to send the power on signal to the board.  can I just short that button out to be powered on whenever power is applied?
Beretta
« Reply #5 on: May 11, 2010, 08:07:24 pm »
hmm that i dont know.
very "set" specific.. i've heard some models you can change it to power on automatically if you get inot the service menu (the hidden one from the factory not the end user one)
some have been able to get them to come on by sticking a tooth pick to hold the power button in.. or just shorting it.
i believe one person hooked up a IR transmitter and was able to get the computer to send a single to turn it on.
this might also work hacking the tv's remote.
im sure there would be a way to send a pulse from the computer.. or you could wire the power button to a double pole momentary switch.. assuming your going ot wire the pc's power button up to a momentary also could turn tv/pc on at the same time.
probably a bunch of ways' i can't help you with nut and bolts specifics.
GameOver
  • That's right. I'm Abe Froman.
  • Last login:February 11, 2013, 06:54:31 pm
  • Got a quarter?
    • Check out my cab!
« Reply #6 on: May 12, 2010, 06:30:04 am »
good advice,
For my set up I use a complicated device to manage this.  You may have heard of it - a remote control  ;D
Don
  • Last login:March 26, 2024, 04:39:03 pm
« Reply #7 on: May 12, 2010, 07:46:11 am »
In a similar question: Does anyone know how to get the TV to automatically turn onto the 'AV' channel (channel that displays composite/scart etc.)? My tv will turn on if the power button is depressed and the switch at the mains is turned on, only it will turn onto the last remembered channel, i.e. 0-99, and not the AV channel.
Sjaak
  • Last login:April 06, 2024, 05:21:26 pm
« Reply #8 on: May 12, 2010, 08:08:23 am »
Try searching on google for the 'Hotel Mode' of your TV. Most tv's have a hidden menu (used in Hotels) to set the default channel when switched on.
bkenobi
« Reply #9 on: May 12, 2010, 12:32:06 pm »
You know, I never considered checking into service menus.  I wonder if there's a way to change this on my JVC.  I've been using WinLirc with reasonably good results forever, but if I could simplify, that would be even better!  Less stuff running in the background is always a good thing.   :cheers:
Don
« Reply #10 on: May 12, 2010, 01:30:37 pm »
I'm using an old Sony Trinitron 20" CRT (Model no. KV-21T3U). After searching around online I eventually found a code to input using the remote while the TV was on standby to turn on the 'Service Mode' (pic attached), I dont suppose you know any way to turn on hotel mode from here?  :D
What is WinLirc? Does it let your TV turn on into AV mode? :)
Don
« Reply #11 on: May 13, 2010, 12:14:11 pm »
fir3b0x
  • Last login:February 18, 2023, 10:26:30 pm
« Reply #12 on: May 13, 2010, 06:15:49 pm »
I wired one of these wired into my AV button to "change the channel" after power on:
http://www.audiovisualdevices.com.au/viewprod.php?catid=&productid=APC602
The device is powered by my PC, and the PC and TV power up at the same time from an energy-saving power strip (PC is the master).
bkenobi
« Reply #13 on: May 15, 2010, 01:18:49 pm »
Winlirc is software that will allow a computer to send and receive IR signals over compatible devices (many of which are an easy DIY build).  Built a serial based unit and have it send the signals to power the TV on and switch to Video-1 once the front end has started up.
http://winlirc.sourceforge.net/
Oh wow!  After no updates since 2006, they just released a new version of WinLirc on May 5!  I just downloaded it and it has been rewritten to support other hardware than just serial.  BUT, since the coder doesn't have serial on his computer, it might not work.  If not, just grab 0.6.5 and you should be good to go!
« Last Edit: May 15, 2010, 01:22:30 pm by bkenobi »
Justin
  • Last login:April 28, 2024, 06:34:53 pm
    • Centipede MAME cabinet
« Reply #14 on: October 29, 2011, 02:14:33 pm »
Where you using TRANSMIT.EXE to send the signals?  Im going after this same route for a solution to Power TV and change VIDEO input...  thanks!
"3 warps to Uranus" -- so I stopped playing!
bkenobi
« Reply #15 on: October 30, 2011, 03:55:54 pm »
I have an AHK script that runs at login.  Here's the pertinent details.
Code: [Select]
  ;Start WinLIRC
  Run, C:\Emu\WinLIRC\winlirc.exe
  ;Turn on TV
  Run, c:\emu\winlirc\transmit JVC_AV-27230 PowerOn 9
  sleep, 3000
  ;Switch to Video-1
  Run, c:\emu\winlirc\transmit JVC_AV-27230 Video-1 9
  sleep, 1000
This is not a perfect solution, but it works pretty well.  The problem I have is that sometimes the TV comes on but doesn't change to video1.  Sometimes it doesn't turn on, but that's pretty rare.  If I had a wired method, I would DEFINITELY go that way!
Good luck.
Justin
« Reply #16 on: October 30, 2011, 04:40:45 pm »
Brilliant, thanks!
By the way, do you know the correct usage/syntaxis for TRANSMIT.EXE?  I have found nothing online.  Obviously you are using it correctly, so can you share with me the instruction on how to properly use it in command line mode?
"transmit.exe -?"
   does not yield any help....
Code: [Select]
 ;Start WinLIRC
  ;Turn on TV
  sleep, 3000
  ;Switch to Video-1
  sleep, 1000
Good luck.
« Last Edit: October 30, 2011, 05:25:22 pm by Justin »
bkenobi
« Reply #17 on: October 30, 2011, 05:31:10 pm »
I don't remember where I found the syntax.  I'll see if I can't locate something in my backups.  I forgot to include an important part, though.  You will also need a config file for transmit.exe to know what command to use.
JVC_AV-27230.cf
Code: [Select]
# this config file was automatically generated
# using WinLIRC 0.6.5 (LIRC 0.6.1pre3) on Fri Sep 22 17:33:39 2006
# contributed by
# brand:             JVC_AV-27230
# model:
# supported devices:
begin remote
  name  JVC_AV-27230
  bits            8
  flags SPACE_ENC|NO_HEAD_REP|CONST_LENGTH
  eps            30
  aeps          100
  header       8000  4000
  one           600   1600
  zero          600  550
  ptrail        600
  pre_data_bits   8
  pre_data       0xC0
  gap          40000
  toggle_bit      0
      begin codes
          PowerOn                  0x00000000000000B8
          PowerOff                 0x0000000000000058
          Video-1                  0x0000000000000088
      end codes
end remote
bkenobi
« Reply #18 on: October 30, 2011, 05:35:45 pm »
Ok, I found it hidden within the README file.   :cheers:
Code: [Select]
WinLIRC
Please see
for information regarding this program.
transmit.exe was written by Scott Baily <baily@users.sourceforge.net>
usage: transmit remotename codename reps
reps is an optional number of times to repeat the code (default=0).
It is public domain, since the code is trivial.
Mainly it is an example of how to send commands to winLIRC
from your application.
transmit.cpp is the source code for transmit.exe
It uses only windows API functions so you should be able to
compile it with any win32 C++ compiler.  Just be should to include
the appropriate header file (#include <windows.h>).
To compile transmit.exe with MS VC++, create a "simple win32 application"
then use this code as the main program.
If you're not interested in modifying the program the only interesting files are:
winlirc.exe
transmit.exe (optional) commandline program to tell winlirc to transmit a code
*.cf (configuration files for remotes)
So, the syntax is:
You have to give the .cf file name which is the definition for the remote you are using for your TV.  The codename is what you have defined in the begin codes...end codes section.  Rep is the number of times you want the code sent.  Since IR isn't perfect, it's typical to repeat the code a few times.  I think the max is 9 times.
Justin
« Reply #19 on: October 30, 2011, 05:40:50 pm »
Thanks you, are a gentleman and a scholar :)
Well, I just checked and my particular TV is not yet deciphered on the LIRC site.  I looked all over the web for remote codes for my TV, and nothing came back.  I obviously need the raw hex codes from what I can see.   I will see what I can figure out.  This is very good info thank you!
Justin
« Reply #20 on: November 16, 2011, 04:23:05 pm »
bkenobi:
I got winlirc and a Transmitter, and have it all working now... thanks!!!
