Main > Main Forum
JAMMA Board Size
<< < (2/2)
Malenko:
NBA Jam and MK3 are pretty big, so is the CPS2 system..... I think all my JAMMA boards are pretty big except for Tekken 2 Ver.B  I'll measure NBA Jam and stuff when I get home
TheGameFan:
--- Quote from: Turnarcades on May 11, 2010, 10:19:52 am ---Also worth mentioning - many of these xxx-in-1 boards are custom PC boards with JAMMA edge connectors, sometimes with an identical-sized secondary board attached via PCB riser feet. There were also some clone boards (I had a clone Golden Axe for example) that used twin boards like this so the bootleggers could replicate the game using a simpler track pattern and generic programmable chips.
I am thinking I'd need to go at least 6 inches tall to accomodate Neo Geo (single slot) and xxx-in-1 boards.
I'm thinking I'd need to add a fan as well, since I'm sure most JAMMA boards were designed to be ventilated in a full sized cab.
RayB:
Just estimating here, but I think the biggest I've seen could go up to about 14" x 20", and then stacked 3 boards tall (4")
TheGameFan:
--- Quote from: RayB on May 11, 2010, 04:17:38 pm ---Just estimating here, but I think the biggest I've seen could go up to about 14" x 20", and then stacked 3 boards tall (4")
That's about what I was thinking. Makes it kind of difficult to build a JAMMA Mini.
Malenko:
biggest boards I have are UMK3 and WWF Wrestlemania, same size 16 1/2" x 11 1/4"
Navigation
Message Index
Previous page
Go to full version
