Author Topic: Gravis Gamepad Pro not working in mala or mame.  (Read 1524 times)
solidteezme
  • Last login:January 28, 2014, 08:01:48 am
  • Awesome!
« on: May 06, 2010, 08:36:17 am »
Dont understand this issue,
Its just on my laptop, i run vista and in control panel it shows the controller and shows the button presses but when trying to config it in mala or mame it just won't map any button presses.
Solid,
bkenobi
Re: Gravis Gamepad Pro not working in mala or mame.
« Reply #1 on: May 06, 2010, 11:59:53 am »
If a game pad shows up in the control panel, then the next step is to verify you have set joystick to 1 in mame.ini.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: May 06, 2010, 12:28:47 pm »
Agreed
« Last Edit: May 06, 2010, 02:49:44 pm by Ginsu Victim »
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #3 on: May 06, 2010, 01:22:09 pm »
+1
Don't confuse him.  He may think it's supposed to be set to +1.   ;)
Ginsu Victim
« Reply #4 on: May 06, 2010, 02:50:07 pm »
+1
Oh crap. I don't even take that as a joke. Thanks, I changed it. :lol
solidteezme
  • Awesome!
« Reply #5 on: May 07, 2010, 02:11:54 am »
Ill try it this evening, Cheers guys
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
« Reply #6 on: May 07, 2010, 02:31:46 am »
Use this tool: Paul's JoyIDs
It shows you what id your joystick is set to and allows you to change it (handy for MaLa)
http://www.wingmanteam.com/latest_software/gadgets.htm#JoyIDs_Utility:
« Last Edit: May 07, 2010, 02:38:54 am by loadman »
bkenobi
« Reply #7 on: May 07, 2010, 12:34:49 pm »
Be aware that if you have multiple joysticks of the same type, JoyIDs will not show you any difference between the two in listing them.  You can use the utility to change ID's (even via batch), but if there is no difference between them in the program, you won't be able to do much other than switch them and hope you get it right.  I have this issue with my Logitech gamepads.
loadman
    • MaLa
« Reply #8 on: May 11, 2010, 01:33:21 am »
aahhh Interesting
