Arcade Collecting > Restorations & repair
Williams Defender Cocktail Restoration Project!
DrumAnBass:
To have a 19" monitor fit you would have to move the monitor support boards further apart. Plus you would have to get a new monitor bezel and clean the black paint off the inside of the glass. It would probably be a lot easier just to stick to a 13". I looked at moving up to a 19" with my Moon Patrol and decided to keep it original with a 13".
The wiring harness is just wires with connectors; shouldn't be a huge deal to modify a cheap JAMMA harness. Interestingly enough - my cocktail started off life as a Defender. If you want photos of what my wiring looks like, let me know.
zzaz3:
I thought Moon Patrol originally has a 19" monitor? I haven't even seen a defender cocktail harness after all this searching, I'd love a picture!
DrumAnBass:
Well my cab started out life as a Defender, sometime before I got it, it was converted. I believe the original cocktail Moon Patrols were 13" as well. It has an original Williams Defender tag on the wiring harness.
Level42:
zzaz3:
--- Quote from: DrumAnBass on August 12, 2010, 09:00:17 pm ---Well my cab started out life as a Defender, sometime before I got it, it was converted. I believe the original cocktail Moon Patrols were 13" as well. It has an original Williams Defender tag on the wiring harness.
I would defiantly love to see a picture of that!
Navigation
[0] Message Index
[*] Previous page
Go to full version
