Main > Project Announcements
Neo-Geo MVS to Xbox cab project
Oni2382:
flip that second switch back up...the only switch that should be activated is switch number 7 (thats the Freeplay switch)
satoshi_matrix:
This is a test picture of my new cab to ensure I can post pictures here.
Malenko:
--- Quote from: Yvan256 on May 06, 2010, 04:49:16 pm ---So you bought THREE Neo-Geo MVS cabinets?! :dizzy:
Are you planning on having spare parts, empty cabs, etc? Building one "perfect" cab from three bad cabs? ???
at one time I had 3. 2 2slots and a 4 slot. I miss them all.
How many cherries do you need? I have like 10
satoshi_matrix:
Ideally I need eight. To my elitist dismay the cabinet has Happ joysticks and Happ buttons. As someone used to Sanwa, the difference is quite substantial. I intend to replace the sticks with JLFs. I prefer the Cherry microswitches to the Sanwa ones, so I'll had to mod that in too.
I'm not sure what to make of my cabinet. It seems to have been heavily modified from the beauties that Oni2382 owns.
Here's my onslaught of various pictures
The basic upper frame.
View from the side. I removed the back plate prior to taking this photo, so it's not missing, just not shown.
A closer look at the top of the front.
Closeup of one of the non-stock speakers. They're stereo and LOUD.
As you can see, the control panel is in quite terrible shape. I'll need to replace probably the entire thing. A friend works for a machinist shop and thinks his team could fabricate a custom replacement. I think I'll go with a high quality plastic instead of metal to reduce weight and cost. As is, it's still functional but god I don't like it.
Inside the control panel here's P1 buttons.
The MVS 2 slot motherboard, cleaned. What are DB-15 controller ports in the bottom right and along the right side??
Size comparison of MVS carts to all other cartridge formats I own. Next time I think I'll include a MicroSD card as well ::)
My MVS lacks the Service/Power module it should have behind the coin door.
Instead it has this power supply to the right of the MVS motherboard. In this picture I disconnect the two AC power lines.
Is this a JAMMA connector?
Ya olde tube. I'll need to remove it to move the cabinet at a reasonable weight, but this thing scares the crap out of me. Where is safe to touch and where isn't? Is there a way to safely discharge it?
My monitor's Technical info. maybe it means something to arcade aficionados?
High tech internal lighting. This makes me happy though; I already have spiral bulbs on hand.
I'll make that it for now.
TEKNYNE:
The DB15 connectors are for joystick and button controls for the system, Many of the MVS can wire controls via the JAMMA connector or by way of the DB15 included on-board. Nice convenience when consolizing a MVS board.
