Main > Project Announcements
The Devil Mame
golfboyusa:
Here's the completed sides. The control panel is going to have a 2" slope from front to back. The casters are installed on the base and on the flipside, the supports for the sides have been attached....
golfboyusa:
I have the sides attached to the base and have began fastening the panel supports and bezel supports. Most of the support pieces are attached with a nail gun.
golfboyusa:
Here's the sound system, neon rings, joysticks, buttons, Ipac2 and the SmartStrip power strip.....
golfboyusa:
I don't have the CP overlay yet, but I wanted to test fit the trackball. I cut a hole 3-3/8" to accomodate the ring spacer, then I used the trackball as a template to mark the mounting holes. The holes were drilled with a 1/4" bit and the mounting studs were tapped in place. While tightening the trackball in place, one of the bolts pushed through a bit too far and caused a bump on the top of the CP. I added some washers and eveything looks good.
rablack97:
Are you gonna use plexi, if so the t-ball isnt gonna sit right. Your gonna have to take a 1/8 inch mdf from the bottom of your CP, where the t-base sits. This is assuming your using 5/8 mdf.
If your using 3/4 with no plexi, the how do you plan to protect your overlay?
