Main > Project Announcements
New Astro City Cab
opt2not:
--- Quote from: Lucky S.O.B. on May 04, 2010, 01:39:57 am ---- Can you tell me the process you went through to sand and paint the cab so it doesn't looked sratched?
He most likely roughed up the surface with sandpaper, then primed it before painting.
--- Quote from: Lucky S.O.B. on May 04, 2010, 01:39:57 am ---- How did you paint it? Most decent paint jobs I have seen used a car paint sprayer...
I've been able to get a excellent look with just a thin high-quality paint roller, and sand-paper. I'm definitely going to go that route with my robotron restoration as well.
Use the search function here, there are a ton of project posts of people using rollers and sanding between coats that you can refer to.
