Main > Project Announcements
Track and Field Cocktail
Pages: << < (5/5)
MinerAl:
With the wood laminate on there it REALLY looks like a Atari Football (c.1979) cocktail cab.
You need to find room for 4.5" trak-balls on your control panels.
brock.sampson:
Certainly closer to Atari Football than Track and Field.  I think Atari Football was a bit darker like walnut this is supposed to like mahogany and a little redder.  Made some more progress last night 95% of the joystick cp is wired.  Need to finish the ground for the last couple buttons and wire up the connector to go to the other control panel, coin door, and power switch.  Sounds like it's supposed to warm up a little tomorrow and Friday so I'm going to laminate the front one of those evenings.
skinz:
WOW!  All this inspiration is making me thirsty!!!   :cheers:
brock.sampson:
Front side laminated last night.  Coin door propped in place for a quick pic.  I was tempted to install the t-molding last night but it was getting late and cold in the garage.  Hopefully I can make some good progress this weekend.  Need to drill holes through laminate for carriage bolts.  That will be scary, reminder go slow so you don't f up the laminate when drilling holes.  If that goes well, clean out all the laminate shavings and mount the computer, speakers, and smartstrip.
Go Huskers!!   :cheers:
Pages: << < (5/5)
Go to full version
