Main > Project Announcements
Track and Field Cocktail
abispac:
--- Quote from: Trap on October 11, 2010, 10:42:25 am ---I use irotate http://www.entechtaiwan.com/util/irotate.shtm for screen flipping. It might be a good solution for you too if you can't get hyperspin to do what you want it to.
Your project is looking great so far!
very interested on this too, as i use hyperspin as well, but bad boy bill dosnt want to implement a rotating in hyperspin...
can you show how we can use this in a cocktail cab with hyperspin please, thanks
Trap:
im just using it for the ability to use hotkeys to manually flip the screen how i want it
brock.sampson:
Making more progress. Bottom corners rounded tmold slot cut button holes drilled. I need to drill one more in the underside of the joystick cp for power and recess them all. Got my first coat of primer on the main cabinet and base tonight. I think I need to thin it a little next time kind of came out spattery but not bad. Not planning on painting the outside trying to source some cheap wood grain laminate for those.
cmoses:
Looking good Brock. I do not think I have ever seen a Track and Field Cocktail before, can you answer some questions? Obviously Player 1 and Player 2 are on one side and Player 3 and Player 4 are on the other. Can all 4 people comepete at the same time in some of the events (100 M dash, 110 M hurddles)? Or are 2 players the most that compete at one time?
brock.sampson:
Nope just two at a time. Sprayed one more coat of primer today and the first coat of black. It was going pretty good until my dog stepped on the door and I got a little over zealous trying to get the slots for the vents black on the inside. I need to learn to walk away I always do this to myself. Nothing a little sand paper can't fix though. I was hoping to do just one more coat of black but those f#!@ ups probably just made it a three coat job. Hoping I can get another coat of black laid down tomorrow after work. Should be warm enough but I think the wind is supposed to pick up.
