Arcade Collecting > Restorations & repair
Smash TV Restoration - Sort Of
MaximRecoil:
--- Quote from: SirPeale on April 10, 2010, 10:51:02 am ---I'm betting Robotron (Smash TV's big brother). Sinistar has a vertical monitor.
I would leave that thing pretty much as-in. That's a damn good conversion.
It is not a Robotron cabinet. Look at the angles in the part I circled in the attached picture.
Edit: I think it is a Williams Splat! cabinet. Judging from the picture on KLOV, it is the same design as a Sinistar cabinet; plus it has a horizontal monitor and the same control layout as Smash T.V.
opt2not:
Definitely not a Robotron. Here's a William's profile comparison picture (ignore the Red Arrow - that was for another thread)
This cabinet could have been a Bubbles, Mystic Marathon, Sinistar, or Splat Cabinet.
flashiv:
Posted by: Q*Bert_24/7
It could also be a Robotron...when you can, open up the control panel and take a picture of the inside of it.
FlashIV : The next weekend or two I'll have some one over to help move it away from the wall. I should be picking up a camera for myself sometime this week I hope.
Posted by: SirPeale
FlashIV : The monitor has been replaced with a new PC monitor by the seller, and the original bezel is long gone. So I don't know if it was originally Vert or Hort.
I am just planning on replacing the re-pro art with "correct flyer" Smash TV re-pro art. BTW awesome restores on your website. Wish I knew 1/10 of that, maybe someday.
Thanks a bunch for the profile pic Opt2not. Looks like I have 4 contenders now. Especially in light of the original monitor not being in the cab anymore. I will check the dates of the other games, to see if any of those also fit the time frame.
MaximRecoil:
--- Quote from: flashiv on April 12, 2010, 02:54:23 pm ---
Even though it could have been any one of those four cabinets, Splat! is the most likely, since it already has the same control layout as Smash TV.
Next in likelihood would be Bubbles and Mystic Marathon. Both of those machines would have required altering or replacing the control panel/controls; in addition to the new board, artwork, and JAMMA wiring.
Sinistar is the least likely, due to its vertical monitor (though if it is easily rotatable like in a Dynamo cabinet, then it wouldn't have been much of a hardship to do so).
Look at the underside of your control panel. Has it been modified? Look for extra holes that have been patched/filled. If you don't see any, then it is almost definitely a Splat! cabinet (or at the very least, a Splat! control panel).
opt2not:
Sinistar would definitely be too much trouble because of the vertical monitor.
My money is on Splat! or Mystic Marathon.
Definitely not Bubbles.
Splat! already has the control scheme, so that would have been a better candidate.
Mystic Marathon because it was a less popular game out of the 3, and being a 1983 release, it would make most sense to convert that cabinet. Though they could have made Splat!'s in '83 as well.
Navigation
[0] Message Index
[*] Previous page
Go to full version
